Custom PC help!
Discussion in 'Hardware' started by JD77, 14 Nov 2005.
  1. JD77
    JD77 What's a Dremel?
    14 Nov 2005
    I made a custom/budget/gaming computer for xmas and i want to be sure that the parts are good/ work properly lol. heres teh list.
    http://www.newegg.com/Product/Product.asp?Item=N82E16814127147
    128MB Vid Card - $75.00
    http://www.newegg.com/Product/Product.asp?Item=N82E16822135106
    WD 80gig HD SATA - $54.01
    http://www.newegg.com/Product/Product.asp?Item=N82E16813131530
    ASUS A8N-E Socket 939 - $109.99
    http://www.newegg.com/Product/Product.asp?Item=N82E16811144103
    aspire Case - $58.00
    http://www.newegg.com/Product/Product.asp?Item=N82E16820145026
    DDR SDRAM 512MB - $39.50
    http://www.newegg.com/Product/Product.asp?Item=N82E16819103535
    AMD Athlon 64 3200+ - $152.00
    corsair Ram 512MB PC 3200 - $39.50
    128mg PCI Express x16 vid card - $150.00
    Aspire - $58.00
    total - $603 no OS
    And what would be better for the 64bit, windows xp home edition or the windows 64x thing?
    and last question.
    Does a SATA 150 harddrive work with a SATA 2.0 mobo?
    thats all =D
  2. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Wrong forum!! :hehe:
  3. JD77
    14 Nov 2005
    well in which one was it suposed to be on? mods plz change it if u can.
  4. Sam0r
    24 Jun 2005
    Hardware and Overclocking :thumb:
  5. sk8phreak88
    sk8phreak88 Minimodder
    8 Aug 2004
    Yep, should be fine, however you show the link at "75 dollar vid card" link takes you to a 6600gt thats 145 bucks. Shouldbe pretty find to game on, my 9600pro, 2200+amd xp and a gig of ram run most games at decent fps with med-high details (cept fear)
    EDIT: You'll need a psu also, I recomend antec and any other namebrand's dont be fooled by the 610watt 49.99 dollar cheap cpu, most of the time, a brandnamed 350watt is more powerfull!
  6. Mister_Tad
    27 Dec 2002
    everything looks fine, but youll need a power supply ;)
  7. JD77
    14 Nov 2005
  8. Mister_Tad
    27 Dec 2002
    that psu will do the treat nicely, as for the OS, windows XP home would be fine for the sake of saving some cash, unless you want XP-64, but id recommend against that, as in my experience it has been a pain
  9. hitman012
    hitman012 Minimodder
    6 May 2005
    All looking good (nice choice on the PSU). SATA is fully backwards compatible, so I wouldn't worry about that.
    As for OS, just get the bog-standard Home. Pro has features you are probably not going to need (Domain-based networking? Policy administration? I didn't think so) and x64 lacks the driver support to justify the small performance increase.
  10. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    hmmm... read the customer reviews on that site... I'm not sure if it's silent and I saw some bad things about the 5v lines among the customer reviews
