Cooling Custom Reservoirs - Mine and Yours, post it!
Discussion in 'Hardware' started by Brew, 9 Jun 2005.
  1. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Hey guys, thought I would post a little blurb on my latest WC project, which mostly involves having twin custom reservoirs feeding twin CSP-Mags from Dtek Customs.
    These tubes were made from 1 1/4 acrylic tube and acrylic solvent from here, 3/8 Danger Den hi-flow barbs, and the top cap is from a bay-res I had laying around.
    There is some leakage from the second and newest tube, they need sealed with silicon still, just did plumbers tape for testing. The tubes will sit farther forward and not on top of the PSU as shown, protruding through the top of the case. Ill have some pics of that soon.
    So there is mine, I think all of you should post pics of your custom res work too :dremel:
  2. Nexxo
    23 Oct 2001
    Do modded reservoirs count? Here's a drilled out Aquatube (adapted for large bore tubing) with integrated flow sensor. :D
  3. Brew
    8 Apr 2004
    heh heh, looking good Nexxo. Where did you get the sensor?
  4. Nexxo
    23 Oct 2001
    From Swissflow (it is the SF800). I just approached the company directly.
  5. Firehed
    15 Feb 2004
    That poor poor aquatube... it didn't stand a chance.
    I've got a criticool waterplant I chopped in half, put a plate type thing that was supposed to help with bleeding high-flow systems (didn't do much :() and a piece of 1/4" round acrylic epoxied on top with a 1/8NPT (I think, I know my G1/8 plugs fit in fine but I know it was an NPT tap) for filling.
    I think its a bit too ghetto to post, but I'll consider it.
  6. Brew
    8 Apr 2004
    come on guys post pics of your home brew resses
  7. mobius9
    mobius9 Minimodder
    4 May 2004
    custom sink res?
    for the el cheapo submerged pump, of course.
  8. Draeth1
    Draeth1 What's a Dremel?
    5 Jan 2004
    Here's mine, I was working quite well until I moved a video card out and put in a new one. When I moved the lines it put too much stress on the barb and cracked the bottom. Now I just have a tline sticking out the hole on the top :(
    Yes I know there is no video card in that pic, it was taken during a leak test before I put it in.
  9. fatty
    fatty Minimodder
    12 Jul 2004
    Heres mine :)
    Its a custom built mach1 with a heat exchanger as a res the water turns to slush at around -14
  10. kbn
    kbn What's a Dremel?
    17 Mar 2004
    Heres a few pics of mine which I have just finnished.
    Parts:
    1x 1liter bottle - rapidelectonics
    2x 3/8" BSPT->14mm OD Barbs - airlines
    2x 3/8" BSPT nut - airlines
    4x 3/8" BSP washers - airlines
    150mm² of 0.8mm alu sheet for the mount
    4x pop rivits
    So total cost only a few quid. The bottle was 72p iirc.
    I havent drilled the mounting holes yet as I need to take my old res out to line it up with the old holes on the mobo tray.
    The extra alu that look a bit wrong on the bottom is there to help support it. As im only using 0.8mm thick sheet.. I thought it would definatly need it.
  11. Brew
    8 Apr 2004
    Lookin good fellas, the custom phase change looks sweet :rock:
  12. biff
    biff What's a Dremel?
    8 Jan 2004
    Here's my res/pump housing. Its not a common pump for WC setups, its a garden fountain or pond pump. I just used it initially 'cause I had it and I bought a Danner Mag 3 to replace it, but I like this pump better so I went back to it. It does a pretty good flow and a Panaflow @ 7V will drown out the sound of this baby... man its quiet!
  13. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Another 1/2" modded Aquatube owner :)
  14. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    here is my custom res.
    Its a pice of pvc tubing I cut then used pvc caps and glued them with pvc cement and sanded it primed it and painted it. Its atached to a case I built but abandoned. That res was for my dead voyager case. See sign
    This is for my other project chromed dragon.
