Modding Custom Screws
Discussion in 'Modding' started by The Infamous Mr D, 18 May 2015.
  1. The Infamous Mr D
    The Infamous Mr D Minimodder
    11 Feb 2008
    I've been looking at modding my new box & one thing I'd like to explore more about is interesting screw types. Specifically screws to replace the #6-32 mobo & PSU standoffs and/or M3/4/5 screws in use in most PC cases. Bitfenix handily included a guide to what screw threads they use in the Prodigy.
    Just wondering if any other modders out there have experience with where to source funky standoffs, screws & washers and the like? I suppose I could source any number of bolts & retap the existing holes - anyone done much of that either?
  2. Nexxo
    23 Oct 2001
    Depends on what you want. Most places sell black high tensile steel and stainless steel socket cap screws. You can also get anodised aluminium screws.
    For Ada I had some brass dome socket screws made by a local company, since they cannot be bought off the shelf. Cost a bundle though.
  3. Teelzebub
    27 Nov 2009
    First place I'd look would be ebay too many to list there
  4. bulldogjeff
    2 Mar 2010
    Unless you have a specific reason for funky motherboard stand offs, like being on show with a clear plexi mobo tray, I wouldn't bother. 99.9% of the time once the mobo is in they will never bee seen again. Other than that as tel says ebay.. Kustom PCs used to do a few different types of the more popular screws in various colors and I know MNPC Tech definitely do them .
  5. Mr Evil
    Mr Evil What's a Dremel?
    17 Apr 2015
    I wouldn't use non-standard fixings for a motherboard tray, or anywhere else that a standard exists, unless there was a particular reason not to. The convenience of compatibility is more important.
    For decorative purposes, Pro-Bolt sell nicely finished anodized aluminium and titanium bolts (for a price).
  6. The Infamous Mr D
    11 Feb 2008
    Perfect, that's exactly the type of resource I was looking for! :)
