Windows Customising XP
Discussion in 'Software' started by R121, 10 Nov 2001.
  1. R121
    R121 What's a Dremel?
    10 Nov 2001
  2. Cheese
    Cheese Doc
    6 Oct 2001
    Double the boot speed eh? Mine boots in about 10s (3 sweeps sometimes!) - will try the proggie though :D
    lol and you really need to see super's customised boot logo and login...
    r. :D
  3. Guest-16
    Guest-16 Guest
    What actually does bootvis do apart from trace your startup speed??
  4. Cheese
    Cheese Doc
    6 Oct 2001
    Wow... bootvis worked! Now loads in 2 sweeps of the bar...
    r.
  5. Cheese
    Cheese Doc
    6 Oct 2001
    Err... nothing. It puts all the files that win uses on startup at the same place in your hdd I think...
    r.
  6. R121
    10 Nov 2001
    So what is super's customised boot logo and login...
    can you post a link ?
    BootVis traces your boot time and it gives you a option to optimise your boot files I can notice only a slightly faster boot up time I have ALOT of drivers to be loaded.
  7. Cheese
    Cheese Doc
    6 Oct 2001
    Super would kill me if I told you... he will surely show the world himself soon :D
    r.
    p.s. 'tis very cool btw!
  8. Guest-16
    Guest-16 Guest
    Can you tell me where that is cause i cant see it!?!
  9. Cheese
    Cheese Doc
    6 Oct 2001
    ?? You load the proggie, go to new and let it take a recording of a reboot of your pooter. Then you load the proggie again, load the recording into it and click on the 'optimise' option in the menu (fourth menu along I think) -- nice and easy :D
    r.
  10. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    Ok, nothing too special just the matrix login screen and carried through to the desktops of the two users I have............
    The Blue Pill...
    The Red Pill...
    ..........I like it anyway. The boot screen is the XPBOX one thats doing the rounds at the mo but I'll be working on my own tomorrow (or whenever I find time....). :)
  11. vivid
    vivid down in fraggle rock
    24 Sep 2001
    i like that login in screen, v cool :D
  12. Cheese
    Cheese Doc
    6 Oct 2001
    Told you so!
    r.
  13. SuperScrubber
    12 Mar 2001
    OK finished my own boot screen now aswell ............
    ............relatively straightforward, just dont flame me for it not being bit on there ok !!! :)
  14. Guest-16
    Guest-16 Guest
    Oooooo puuuuurdy :)
    I cant seem todo any of mine!?! none of the changes ever take effect :( even though i save them and replace the file where it came from!?!
  15. ZeffriN
    ZeffriN What's a Dremel?
    11 Sep 2001
    WOW Superscrubber
    I liked the Matrix one better personally... but... Only lets you have two users.
    Still nice though!
    I want to make my desktop etc look nice, but it's very hard
    lol
    I'm artiscally challenged
  16. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Where could one blag a copy of that matrix login screen :)
  17. SuperScrubber
    12 Mar 2001
    The matrix login screen can be found here among others :)
    The SS thing is my boot screen ie.when windows is loading, then it pops on to the login screen ........... the user names and icons I used to tie it in a bit (just do an img search for "blue pill" and "red pill" if you want the icons).
  18. Fly
    Fly inter arma silent leges
    31 Aug 2001
    There are some really cool ones there...
    /me rubs his hands with glee!!!
    Fly
  19. lowtech
    lowtech What's a Dremel?
    24 Oct 2001
    thats WAAAY COOOLL...screens...:cool: :cool: :cool:
  20. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    How'd you get a red Scheme.. mine doesn't have that option and I couldn't see anywhere to create them?
    If I'm being dumb or it's obvious, skirt round it and tell me tactfully :D :D
