Modding Cutting a Chieftec Dragon FULL tower case. Am I doing something wrong?
Discussion in 'Modding' started by bixie_62, 29 Apr 2009.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    Hi all
    Well, I'm watercooling for the first time here, and I'm trying to do everything properly.
    I've got my pump, tubing, radiator, block, fluid etc and now I'm just trying to figure out a way of mounting the radiator.
    I've decided that I'm going to have it screwed into the top panel of the case, however, this is where I hit a snag.
    the 'top' of said case, appears to be made out of some kind of very very strong steel!
    I tried drilling the holes for the fanst first, but eventually the battery on the cordless black and decker ran out from a full charge, it just couldn't cut it.
    then I whipped out my dads super old 'made in West Germany' Metabo hammer drill, eventually managed to drill the 8 holes required.
    However, now its coming to cutting out the hole for the fan and its looking pretty difficult, I was dremelling away for about 15mins and manage to make a 'scar' on the case about 5 inches long and a cut right the way through about an inch or so of them 5 inches!
    what am i doing wrong?!
    am i just being impatient, or is there a better way of cutting this damned fan hole?! i'd like to have it all cut today if possible, but unless i can think of a better way of dremelling that thick steel then i'm gna be here all night!
    can anyone impart some advice?
    by the way, im using one of those reinforced cutting discs with the dremel if it helps at all, and the drill bits i was using were pretty much brand new, and had just been sharpened by my dad at his machine workshop
    many thanks
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    you need to let the tools work at there once pace, forcing it will over heat it and potentially break the cutting bit.
    Steel is a B**** to cut, nothing new or different in your case. Modern battery powered tools are pretty crap on average when it comes to cutting or drilling steel. Good HSS drill bits also helps alot, cheap ones blunt very quickly and aren't worth the money spent on them.
    take your time, especially if its your first time cutting, try to keep the cutting bit cool as possible so a little WD40 to cool as you drill or cut.
    A good hacksaw blade will help alot, compared to a dermel, it all honesty there crap for cutting steel, there better at sanding than cutting.
  3. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey burnout
    many thanks for the reply
    well, i've got dad making up a handle for a hacksaw blade that i can rotate properly, so hopefully, i think im going to end up just using a hacksaw to cut the damn stuff!
    trying to make the cut look as clean as possible though, and its not really working!
    the drill bit i used initially was a POS, managed to get one from my dad that was really high quality, that practically sliced through the steel
    part of me is thinking about just literally drilling a series of holes as a template around where im cutting and then just using either the dremel or some tin snips to cut the bit between each hole
    ah well, gna mark that up when i get home from uni today, hunting for a suitable grill right now though
    cheers
  4. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    That is probably a better idea IMO. Its easier to just sand down a bit than to have to go around cutting the entire thing. Just make sure your drill holes are as close to the line as you can get as this will reduce the amount of sanding.
    The dremel should then come into play as with a good emery bit it should chew through the steel pretty good.:dremel:
  5. Burnout21
    9 Sep 2005
    Steel is far to hard for a dremel to cut to be honest, all it will do is bounce around, make alot of noise and take twice as long compared to a good sharp file and a little hard work.
    dremels are toys.
  6. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    That's a joke right?
  7. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    This. I used a Bosch hacksaw with a fine toothed blade when I was modding my Chieftec Dragon back in the day. You'll have to be patient, though. Even with a hacksaw, it will take a while to cut. As mentioned, you just have to let the tool work on its own, without pushing it too hard. Patience is key. Remember to use lots of masking tape. :)
  8. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    azazel, are you talking about a hacksaw or a jigsaw? hacksaw is a hand tool, jigsaw is a power tool (and awesome).
    if you do stick with the dremel, just be patient. it does take a while, especially when cutting curves. i have to concur with burnout though, a dremel is a toy. especially if it's a cordless dremel, they just don't get the RPMs you need to cut through steel.
  9. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Oh, my bad. Got mixed up, hehe. I meant jigsaw, of course. :)
  10. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    eh waht?
    my dremel does more than well against steel as long as I'm using the fiberglass reinforced cutting bits
  11. kenco_uk
    28 Nov 2003
    Aye, I used a jigsaw with a couple of cheap metal cutting blades to cut into the side of my GW-802 case way back when. Drilled a hole for the blade to fit through and it was fairly easy from there. You have to either clamp the metal piece down or sit/kneel on it, else it'll bounce like a kangaroo on a pogo stick.
  12. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    Hi all
    well, since my last post i've managed to drill out the template for the blow-hole
    i think its around 100 or so little 4mm holes with 1mm gap between, not toooo bad, but not fantastic either
    so, my question now my fellow bit-ers, i have managed to acrue a large amount of 'shavings'/bits INSIDE the case, how do i go about removing these?
    I was thinking of completely removing all of the wiring (power buttons/led's etc) and just dunking the case in a bath of warmish water?
    or should i invest in a can of compressed air?
    many thanks
  13. Volund
    16 Sep 2008
    shopvac or even a conventional vacuum with a wand attachment will take them right out.
    hope to god you weren't cutting with your hardware inside (yes, I've seen that done)
  14. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    shite
    knew i forgot something!
    lol, nope, the only stuff that remained were the junky fans and the case wiring really, nothing tooo critical!
    i think i might be giving it a bath too.lol. and perhaps a good sand down/paint job too maybe, we shall seeee
    need to get this damn grill cut out, that'll happen tomorrow im guessing once ive got a scrollsaw blade
    cheers
  15. Volund
    16 Sep 2008
    make sure you dry it really well or you will have rust issues on the cut edges
  16. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    i was thinking hair-dryer? that ought to do it i reckon
    and, most probably, unless i can get a bottle of spray-paint perhaps even a bottle of nail varnish perhaps to cover the edges, was beginning to get a little worried about those edges of bare steel!
    cheers
  17. Slaymate
    Slaymate bit-tech Slayer
    15 Feb 2009
    A picture says a 1000 words. Show us some pictures :D
  18. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    well, i've taken a few pictures, can someone guide me in the right direction as to how to upload them? i've never done it before so am clueless to the process!
  19. Guest-23315
    Guest-23315 Guest
    bixie_62 likes this.
  20. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    HI all
    well, lets try attaching this:
    well thats the first one showing the radiator that im gna be attaching
    and again below showing the blowhole in a little more detail
    should i be using a scroll-saw blade from here then?
    Cheers
