Modding Cutting Acrylic
Discussion in 'Modding' started by culley, 29 May 2007.
  1. culley
    culley What's a Dremel?
    12 Jul 2006
    What's the best method to cut acrylic, is it with a Dremel and the right cutting bit or would it be better to do it with a band saw, I'm seriously thinking of buying a cheap one lol.
  2. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    It depends on a few things.
    1. Thickness: if its thin (like really thin) then you can just use the score and snap method but if its thicker, like 1/8 inch at least, then some sort of saw must be used.
    2. Type: If its cast acrylic, you're good to go with just about any method. If its extruded, good luck keeping it from melting.
    3. Straight or curved: Obvious really.
    Overall. If I were you, I'd get the bandsaw. Not only will it cut acrylic pretty nicely, you can also cut metal and wood on it which will be very helpful for future mods and such. A worthwhile investment definitely. First and foremost, good luck with your project.
  3. culley
    12 Jul 2006
    Thanks for the advice greensabbath
    I'm not to sure if the acrylic I bought is cast or extruded its AC Ryan AcrylPanel 5mm 480x480mm - UV Green anyone know what type this is?
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
  5. culley
    12 Jul 2006
    You know I would buy a band saw without the blink of a eye if I had somewhere to put the damn thing, I could put it in my shed no problem but there like 1.5m tall. I would prefer a table one.
  6. x06jsp
    2 Apr 2007
  7. Cheapskate
    13 May 2007
  8. greensabbath
    19 Apr 2005
    A masonry saw for cutting acrylic? Interesting. What blade do you use?
    @culley: Either of those small bandsaws that x06jsp suggested would work although I agree the top one looks better. That other bandsaw he suggested is a friggen beast... I like it.
  9. x06jsp
    2 Apr 2007
    lol the big one looks awesome doesnt it!!! and its relatively cheap!!!
  10. greensabbath
    19 Apr 2005
  11. x06jsp
    2 Apr 2007
    o i thought it was floor standing too!!! lol
  12. culley
    12 Jul 2006
  13. greensabbath
    19 Apr 2005
    I totally forgot to mention that. Very useful tool. I have a really simple one that i've had for 8 years or something and I love it, Good Choice.
  14. x06jsp
    2 Apr 2007
    that dremel one looks awesome just like all the dremel products!!!
  15. Cheapskate
    13 May 2007
    I use the diamond blade that came with it. It works with everything BUT lexan. Older, worn out blades cut even cleaner.
    I'm going to try that plastics shop you mentioned in the other thread. Awesome prices!
  16. greensabbath
    19 Apr 2005
    Thats really interesting, I never thought it would work. Could you possibly take a close up picture of the edge of one of your cuts? I just have to see it to believe it.
    I'm making an order to Delvies too as we speak.
  17. Cheapskate
    13 May 2007
    Wetsaw cuts...
    Forgive me! I have no way to optimize this pic on this computer...
    The first edge is 1/4" polyprophelyne with a new diamond blade. The second is 1/2" acrylic with a broke-in (I've tiled about 7 houses with this blade) 10" diamond blade. The red is a 'factory' dry cut. The scan really doesn't show how rough the red is in comparison.
    Keep in mind all the plastic I've used up to this point was used, so I have no idea how the paper masking on new plastic will react to this technique...
    I'm a big fan of your work -looking forward to seeing your new project come to life!
  18. greensabbath
    19 Apr 2005
    Thanks a lot for posting. The second piece with the used blade is impressively smooth. Do you think its the blade itself or the water combined (if you use the water too) that makes it so smooth? Normally i just use a really good blade on table saw but it can still look like the crappy factory edge sometimes.
  19. Cheapskate
    13 May 2007
    I wouldn't try this without the water on! The blade used on the middle cut is very smooth and has almost no grit on the edges. I'm amazed it still cuts tile. I think the reason it cut so well is because it was done on a sliding table-type saw that holds the work very steady...
    http://www.sears.com/sr/javasr/prod...subcat=Tile+&+Cut+Off+Saws&BV_UseBVCookie=Yes
    ...one of these. Not exacty standard equipment... It's also limited to an 18" cut.
    I may sacrifice the blade on my little saw by hacking a concrete block up. That should smooth the edges on it a bit!
  20. Drexial
    Drexial Minimodder
    28 Jul 2005
    i feel like a jigsaw would work in the place of a band saw as well. those can be a lot easier to work with and the size of the piece will never be an issue.
