Modding Cutting acrylic
Discussion in 'Modding' started by TechZimmy, 2 Jun 2004.
  1. TechZimmy
    TechZimmy What's a Dremel?
    17 Apr 2004
    Whats the best way to cut acrylic? I have tried a dremels and hacksaws and jigsaws and box cutters, but it never comes out right.
  2. dslrennwagen
    dslrennwagen What's a Dremel?
    25 Feb 2003
    what do you mean by "right"? i think generally just go slow to avoid burning it, and then run a flame over the edges to get them clear again.
  3. TechZimmy
    17 Apr 2004
    when i cut it with a dremel it stinks really badly. When i use a hacksaw it cracks the edges. When I go over a line 1000 times with a box cutter then try to snap it (score and snap) it just wont work at all (just kinda breaks in the wrong spot) Ill try the flame thing
  4. dslrennwagen
    25 Feb 2003
    ok, it sounds like maybe you have the dremel speed to high and its melting (burning) the plastic. and if i wasnt clear, the flame technique is to _get_ cut edges clear again, not to cut them
  5. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    1. jigsaw with a fine tooth blade (GO SLOW)
    2. go over it about 10 times with a razor blade pushing down hard and make sure the blade is sharp, dont cut yourslef! clamp it down real tight with some clamps with you line you cut right on the edge of a table,workbench or whatever you have and then in a very fast motion push the plastic down and it sould give you i nice break
    3. dremel cut off wheels, cover the area you want to cut with masking tape and go slow and then sand it nice with a plastic file
    those are the three main things i do to cut plexi, acrylic, etc. and the all work like a charm for me
  6. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I cut all my acrylic with a hack-saw. Very accurate cuts.
    http://server5.uploadit.org/files/jeffrey9-mm02.jpg
    http://server5.uploadit.org/files/jeffrey9-running7.jpg
    http://server5.uploadit.org/files/jeffrey9-light_magic.jpg
  7. tmod
    tmod What's a Dremel?
    9 Apr 2004
    There are many ways to cut acrylic, but I find a hacksaw (fine-toothed) to be very effective for smaller, straight cuts.
    Also, try this for more good info on working with acrylic.
  8. ede670
    ede670 What's a Dremel?
    26 May 2004
    yep use a hacksaw as well but put that cheap masking tape on the acrylic then draw the lines on it . ? dont know if it helps prevent splits as I havnt had any :p
  9. D B
    D B What's a Dremel?
    11 Apr 2004
    I use a X-acto knife , pointed blade ... the trick to scoring the plastic is to use the knife with the blade backwards and hold it allmost vertical to the surface , like this .... \l -> pulled this way , you will get long curls of plastic coming off the blade and If you do it like this it won't try to cut it's own path , insted of following a scratch mark you made . I try to go at least 1/2 way through for straight cuts and all the way through (allmost) for very curved ones . Make shure you support the piece just behind the score when you go to break it.
    DB
  10. NissanFrontier
    NissanFrontier What's a Dremel?
    18 Jun 2003
    I use the attachment for the dremel that makes it like a Roto-Zip and cut about 1/4 of a inch away from the line I want to cut. Then I take a metal ruler and clamp it down to the line. Then I take a a drum sander for the dremel and sand to the line. Then I take fine sandpaper and then take cardboard to buff the edges smooth. Sounds crazy I know but it works.
