Electronics Cutting Device
Discussion in 'Modding' started by Explicit, 2 Sep 2004.
  1. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    So i need to cut some foam insulation. I saw how they cut it in the factory to the sizes you get for building a home...
    They use a wire that has current running through it, and it heats up enough to cut right through...
    Anyone have any idea how I could make something similar? It only needs to be about a foot and a half long.
  2. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    i've seen home made ones made out of a wood or pvc. the pvc ones looked easier to make. they basically made a Y with the tubing then at the ends of the y they added an inch or two of al with a connector on the end for the wire to be strung between. hope this helps.
  3. kaptin
    kaptin What's a Dremel?
    27 Aug 2004
    think in terms of a 50w soldiering iron.....execpt with a wire instead of an iron...you just have to get like 6 gauge stainless steel wire...that way it doesn't melt from the heat :)
  4. Explicit
    23 Dec 2002
    How thick is 6 gauge steel wire?
  5. Explicit
    23 Dec 2002
  6. OmegaX
    OmegaX What's a Dremel?
    1 Aug 2004
    if u want a guide here's one
    foam cutter
    u might have 2 look, it should be the first one
    basically u take a doorbell transformer and run that current through wire like previously said
  7. Explicit
    23 Dec 2002
    Wow, that's great. Thanks!
  8. kaptin
    27 Aug 2004
    oops...wrong guage...i ment 11 guage...that should be thick enough for low watt...6 guage is a little thick...like 2cm ...and it does matter what material you use...i guess violin string would do great..didnt think of em :D
