Cooling Cutting Hose
Discussion in 'Hardware' started by airchie, 21 Jan 2007.
  1. airchie
    airchie What's a Dremel?
    22 Mar 2005
    OK,
    I'm about to do the whole water-cooling thing again and I was wondering how you guys cut your hose?
    I always have a nightmare getting the cuts straight...
    TIA. :)
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Take a sharp knife, and push down on the hose while it sits on the desk. It's important that the knife's sharp though, or the cut'll slide off in either direction.
    If you want to do it properly, John Guest make specialist cutters for hoses. They work brilliantly, but are ~£20 IIRC.
  3. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    take a pair of SHARP scissors, and cut the hose, but be sure to cut it exactly perpendicular to the hose, so the outside and the cut make a 90 degree angle.
  4. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    I should think that the same pipe cutting tool plumbers use for copper or PVC piping would work.
    I've always been lazy and just used a box-cutter though.
  5. Krikkit
    21 Jan 2003
    Just use a sharp stanley knife.
    Get a box, or anything with a good angle, then slice directly down with the knife. If you get a wonky cut, you can always trim it with a properly sharp knife.
  6. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Meh, I just used a sharp pen knife blade.
    Worked fine!
  7. airchie
    22 Mar 2005
    Yeah, leaning towards a sharp stanley knife.
    Might have to raid the store at work to see if there's any new ones 'going spare'. :)
  8. buchans
    buchans What's a Dremel?
    28 Jun 2004
  9. airchie
    22 Mar 2005
    Hehe, that's the one I bought but it doesn't work.
    Is there a particular technique??
  10. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i use a good pair of fiskars scissiors, they work fine, cut though anything they will.
    with cutting tubing never try to push down, you need to slice across it, so a long kitchen knife and a flat surface will work well.
    treat the tubing like when you cut meat and you will have no troubles.
  11. buchans
    28 Jun 2004
    I use it upside down compared to the photo, put the tube in then push blade down into it
  12. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    or use the same thing they use to cut pieses of wood at school. I dont know how you call it in english. But it looks like a |_| profile. It looks like this in the length |_||_|.
    You cut in the middle of the thing :D
    Hope you understand my thing :D
  13. airchie
    22 Mar 2005
    I think you mean a mitre-box.
    I've got a nice new set of razor blades which should do the job... :)
  14. 1e8o
    13 Oct 2005
    I think I do :D
  15. airchie
    22 Mar 2005
    w00t, I got it sorted.
    One stanley blade, not a lot of pressure and a sawing action did the trick.
    I'm typing this on my fluorinert-cooled PC now... :)
    Thanks for all the replies guys. :)
  16. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I've got a hose cutter too - works cleanly, easily, and nicely. You could also use ratcheting PVC/plastic pipe cutters.
  17. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I use a PVC cutter, perfect ends every time.
    Harbor Freight for the... well, you know.
  18. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    kool where do you get a PVC cutter from? i have been using sharpe scissors but would be keen on geting the right tool for the job, since tygon costs a fair bit.
  19. KayinBlack
    2 Jul 2004
    I got both of mine from Lowe's and Harbor Freight, but as you're UK, I have no idea where to direct you. It's actually made for cutting solid Schedule 40 pipe, so it'll do tubing no prob.
  20. Krikkit
    21 Jan 2003
    I find a stanley knife works best if you fold the tube at the correct length, then cut the stretched bit. After that, you can just trim any rough-sections no probs. :)
