Modding cutting screw holes for 120mm fan
Discussion in 'Modding' started by NOMIS, 3 Jul 2005.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    ok so i've cut the main hole into the case to let air in, but how do i go about cutting the screw holes? i have tried many a time previous and 1 or 2 are always out therefore no screws can go in them unless i can squash/warp the fan :p
    this time i want them to be purrrrfect
    what's the best way? i don't have a 120mm fan grill to use so must be another way eh :p?
    thanks for any help
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    use your 120mm fan?..., just position and then w/ a sharp point mark a spot or use a really small pen, or its ink cart
  3. NOMIS
    7 Jun 2004
    yea i could use that but i have problems seeing that its lined up properly lol!
  4. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    i do it this way:
    mark and drill one hole, put the fan on that hole and line it up with a screw.
    mark a second hole, remove the fan, drill the hole replace the fan and line it up with 2 screws.
    mark the last 2 holes, remove the fan and drill the holes, hopefully the fan fits now.
    It's much easier to do than it is to describe.
  5. NOMIS
    7 Jun 2004
    good idea man! i'll use that method :) cheers
  6. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Either that or make a jig. That is what i do. I just use a fan to draw everything on like a peice of cardboard. Then drill and cut it out.
  7. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    The tool you need is a "transfer punch", just a steel pin with a sharp tip in the center of one end. They come in sets that look like http://www.precisionmeasure.com/tool10.htm. If you only need that one size you can try to make one yourself.
    Get a drillbit, preferably one that is broken off. It should fit tightly into the hole on the fan. Put the bit into the drill so the dull end sticks out. Turn on drill and grind a tip onto the bit with sandpaper or a file. It's not as easy as it sounds to get the tip centered check the result carefully before you use the modded bit as transfer punch.
  8. Ghlargh
    16 Nov 2003
    I have perfected that method for when i made some carbide tipped drawing pins for hard metals.
    I put a diamond coated cutting disc in the flex-arm of my dremel copy and secured the flex-arm pointing straight up in the vice-clamp or whatever you call one of these.
    Then i put a worn out carbide endmill in a battery drill and held it at a fixed angle to the flat diamond covered side of one of the diamond coated cutting disc until it had a nice sharp tip.
    this should work just as fine with a worn out drill, just don't push too hard or you will get the HSS-steel drill too hot and take the hardening out, making it as soft as regular iron.
