Planning Cutting the 250D Front Panel
Discussion in 'Modding' started by Redbeaver, 18 Jul 2014.
  1. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Hello folks.
    Here's what one Danish guy did to the removable front panel of his 250D.
    So... I get the way he glued the fan frame, sand it down and repaint. Cool.
    But how did he CUT the panel in the first place?? What do you guys recommend cutting?
    Because depending on the answer, I might want to skip the frame and just cut some graphic art on the panel directly.... I'm not in front of mine right now, but it's definitely not Plastic. More like stainless steel.
    Thanks,
    PS: or i could be wrong. i could be plastic. again im not home at this moment LOL :wallbash:
  2. Redbeaver
    15 Feb 2006
    Ah......... nevermind folks. It's plastic.
    Hard plastic (some kind of hard resin?) but not metal.
    Any recommendation on cutting though regardless?
    I'm thinking Dremel but it could get a bit messy.....
  3. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Dremel would probably be fine but you could make a starter hole then use a jig saw.
  4. Redbeaver
    15 Feb 2006
    Hmm i dont have a jigsaw. But i dont think those stuff is expensive. thanks!
    last time i did some custom vent cutouts was on an Antec case, about 13 years ago lol.... stainless steel with a dremel. SPARKS!
