Modding cutting window
Discussion in 'Modding' started by kaneso, 31 May 2004.
  1. kaneso
    kaneso What's a Dremel?
    30 May 2004
    well i hav a top window on my case and i wanted to put a fan and guard at top but will it snap the window and wat is the best way to do it?
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Do you mean cut a round hole in acrylic? I cut all my "straight cuts" with a hack-saw, but for a round hole a dremel will work (not a max speed it will want to melt the acrylic) or a hole saw. Or you could just drill a few holes (in some sort of pattern through the acrylic and then drill your holes for the mounting bolts (that would look better, I think). Good luck and post some pictures when your finished.
    MS
    http://server5.uploadit.org/files/jeffrey9-mc01.jpg
    http://server5.uploadit.org/files/jeffrey9-bluemonday.jpg
    http://server5.uploadit.org/files/jeffrey9-running7.jpg
  3. modsquad
    27 Feb 2004
    Sorry, here's a picture of my fan grill. You could do the same with your top window.
    http://server5.uploadit.org/files/jeffrey9-light_magic.jpg
