Hardware Cyberpower Gamer Infinity CrossFire HD
Discussion in 'Article Discussion' started by Guest-16, 5 Aug 2008.
  1. Guest-16
    Guest-16 Guest
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Is there any reason there are two different brands of 4870?
    Nice to see fair pricing for prebuilds - I'm sceptical as to how long they'll last..
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Okay, who's bringing the average down?
  4. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    They are both HIS cards, look at the fans. Sometimes the bundle includes stickers.
  5. Glider
    Glider /dev/null
    2 Aug 2005
    Probably those with jobs or a life... :rolleyes:
  6. liratheal
    20 Nov 2005
    I was just curious as to the fact that one, in the last picture, has a Radeon sticker, and the other doesn't. Didn't know whether they were different models or something.
    How dare they have lives!
  7. CyberpowerUK
    CyberpowerUK Cause & Effect
    5 Aug 2008
    Hi There!
    This is Mike from Cyberpower UK. If anyone has any questions I'd be happy to answer them either here or direct by email as well, michael[at]cyberpowersystem[Dot]co[Dot]uk
    @Liratheal they are both HIS cards. One came OEM and had no sticker the other was retail and did so they look different because of that, sorry for any confusion.
    Mike
  8. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    when did bit start doing max playable reviews?
  9. liratheal
    20 Nov 2005
    Ahh.
    Fair enough, then :D
  10. Guest-16
    Guest-16 Guest
    Because we've nothing to compare it to directly so we wanted to give you what kind of experience you get when you buy a system like this.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    We're happy to announce that bit-tech readers will be able to get the exact same system we reviewed, including that whopping 4.0GHz warranty guaranteed overclock, for just £999.99. Considering the system was already good value in comparison to self build components, this now means it's a very tempting option for anyone looking for a full system gaming machine.
    All you need to do to take advantage of the offer is mention bit-tech when placing your order. The offer will be running for the next six weeks.
    Thanks Cyberpower - Nice One!
  12. CyberpowerUK
    5 Aug 2008
    You're welcome :)
    Mike
  13. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    Cyberpower is an awesome company. I purchased my first pre-built PC from them and they sent an upgraded case (by accident idk) and the system's been going for almost 6 years now. I would definitely recommend them. They can be on the high side though on peripherals, so watch out there. Glad to see they're offering quality products and competitive pricing....
  14. Jojii
    Jojii hardware freak
    12 Dec 2007
    But the question remains..
    Does it blend?
  15. R3veNG
    R3veNG You were R3veNG'ed >:-)
    12 Dec 2007
    I'm quite sure this pc is too big for a simple blender..
    So the REAL question that remains is: "Does it blend the blender?"
    R3
  16. p3ri0d
    p3ri0d What's a Dremel?
    9 Jul 2008
    So someone go buy it, and try to blend it then we'll see what blend before the other :p
    oh! btw, R3veNG it took me 3 secs, not 7 :p
    Actually I think it's a great thing that pc, real good stuff for a real good price ;)
  17. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Hmm, not sure how prices are generally in the UK, but from what I've seen, Cyberpower's other systems are a tad on the expensive side, custom building is still more affordable. I'm also disappointed by the choices of odd cooling solutions (rather limited) that they offer. No Zalman? No Noctua? Water cooling limited to 1 no-name model/brand? And most of the power supplies (actually from what I can tell, all but the Corsair) are pretty cheap 4-6 rail power supplies, some better single rail solutions would be nice. There is a nice selection of cases however, hard drive and GPU solutions which is convenient. The emphasis on nVidia chipsets is a bit of a turn-off, since they aren't really worth the PCB they're made on (dollar for dollar performance / reliability versus Intel/AMD chipsets).
    At least it's not as bad as Alienware, Falcon North-West, Voodoo or Widow PC which just add some shiny paint on a case and claim a $6000 price tag.
  18. wyx087
    wyx087 Multimodder
    15 Aug 2007
    not so keen on PSU, case, CPU cooling, HDD and memory choice, as i've not had any good experience with OCZ memory, and not heard good things on Hyper after Corsair started making Hx620w.
    but being a system builder myself, i am very picky. that system is very good value. though could have added £50 for a F1 drive, TRUE as cooler and Corsair Hx620w?
    when did Bittech start doing whole system reviews? i thought there's going to be P45 reviews poping up
  19. Jediron
    Jediron What's a Dremel?
    22 Jul 2008
    OCZ is great memory, i have never had any issue's with them. Afcource, anyone can have a bad experience with memory, from any brand. The fault could just as well lie with the motherboard in use. So to scrap OCZ from the list is not a goodf idea. OCZ is very populair, an for a good reason; overall they are just plain good.
  20. wyx087
    wyx087 Multimodder
    15 Aug 2007
    OCZ are very, very good at their rated speeds. but any higher, even 50Mhz higher will see them suffer.
    Corsair on the other hand, expensive, but 100Mhz higher at stock volts no problem.
    that's my experience on Abit iP35 Pro, not a push-over motherboard by any means
Tags: Add Tags
