Reviews Cyberpower PC Infinity X66 RTX Review
Discussion in 'Article Discussion' started by bit-tech, 20 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    It's not as linear as "they're not that great."
    AIOs are usually compared to Noctua, which is honestly le créme de la créme of air cooling.
    They take longer to heat-soak because the heat is transferred elsewhere, thus usually taking longer to reach peak temperature than [Noctua] air coolers, even if that temperature is higher.
    Regardless of that, AIO has a coolness factor that air cooling does not.
    MLyons likes this.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Safer shipping. An AIO has a little block and pump attached to the board and the big-ass radiator mounted to the case. A tower cooler has a big chunk of metal hanging at some distance off of the board. Delivery truck goes over a large bump or air freight has a hard landing, and you now have a RMA shipment to deal with for a rather large package (and a big-ticket component you need to eat the cost of replacing due to damage).
    jb0 likes this.
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Well, the *real* answer will also factor in the pricing/arrangements Corsair can give an SI. Notice which case and RAM is also being used.
    MLyons likes this.
  5. Fares
    Fares What's a Dremel?
    7 Dec 2008
    Now I need to know what monitor looks great next to this...
Tags: Add Tags
