Hardware CyberPowerPC Hyper Liquid 600 Review
Discussion in 'Article Discussion' started by Dogbert666, 30 Sep 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. David
    7 Apr 2009
    I'm struggling to understand the thinking behind this one.
    The custom loop with rigid tubing is an incredible expense over the cost of an AIO, and only makes sense if it allows for easy expansion of the loop in the future. However this is hampered by the placement of the pump/res and the choice to fit a 240mm rad on the bottom, when a 360mm would make more sense.
    They probably could've mounted the pump/res on the motherboard tray and left the front rad mount available for another rad or even just for additional fans to improve GPU cooling, which appears to be slightly hobbled by the choice and placement of the existing cooling setup.
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    Yeah...but it looks cool, all those tubes, all those lights!!!
    Superficiality sells.
  4. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    There are so many why did they do that, I don´t know where to start.
    As it´s been said before, why not use a simple aio with a 280 radiator and use the Stock 140 Fans that came with the case ?
    Why using the fans as the did it ? Just mount the fans from the Radiator under the radiator and let them suck in fresh filtered air through the airfilter, and use the rear as exhaust.
    Why did they use such a useless mounting bracket for the res so that they can´t even re-use the front airfilter ?
    2 inblowing front fans would help the GPU, and a litle bayres or even a bayres/Pump combination would be a neat idea.
    With a Bay-pump-res the Rigid Tubing would even make sense, as it´s really hard to do a bayres with soft tubing and a floor mounted radiator.
    I managed to fit a 360+240 + EK pump/res combo which is sufficient cooling for a watercooled 980ti&6700k. But I missed out the fancy hard tubing (because of costs)..
    http://www.overclock.net/t/1582467/...00q-inverted-atx-full-tower/350#post_25235258
  5. Vault-Tec
    30 Aug 2015
    It looks OK I guess. However, I would much rather have the GPU on water than the CPU.
  6. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Lower CPU tube isn't parallel with the upper - once you see it it's just not right...
  7. Vault-Tec
    30 Aug 2015
    Yeah I clocked that too man.
  8. Taua
    Taua What's a Dremel?
    20 Sep 2014
    "There's also a radiator, specifically the Alphacool Cape Corp Coolplex Pro 15 LT"
    I think you mean Reservoir :D
  9. Taua
    20 Sep 2014
    also agree, pointless, put the part sucking down 200w with dem mad clocks yo' on water, not the CPU which could easily be done with a fan, or better yet, inclusion in the loop...at that price it's what i'd have expected :/
Tags: Add Tags
