Hello everyone, The theme is Cyberpunk 2077-Deconstruction and will focus on the most eye-catching Mantis Blades in the repair and deconstruction game! Specs: INTEL I9-10900K AORUS Z490 XTREME AORUS GeForce RTX 3080 MASTER AORUS RGB Memory 3200MHz GIGABYTE NVMe SSD 1TB AORUS P850W 80+ GOLD Modular COOLER MASTER MASTERFAN SF120M ALPHACOOLEiszapfen Laser Fitting With 4pin Molex Water cooling: Bitspower Premium Summit M Mystic Black Metal Edition Bitspower D5 Vario Motor Bitspower Leviathan XF 120 4xG1/4" Radiator Bitspower Water Tank Z-Multi 50 V2 Bitspower Touchaqua In-Line Filter Bitspower Touchaqua Digit Thermal Sensor Bitspower Touchaqua Digital RGB Multi Function Controller Bitspower Touchaqua PWM FAN Multi Function HUB Bitspower Fittings Massive thanks to Cooler Master, AORUS, NVIDIA GeForce Taiwan, Bitspower, ModMyMods for supporting my projects.
3D model Divided into two parts, The first part is a sketch of the base of the repair table, The second part is the appearance of Mantis Blades. I removed the external skin and changed it to the concept of a metal exoskeleton. Draft computer drawing. 3D modeling.
3D printing This time there are about 90 3D printed parts, contains FDM and DLP. Make skin mold for clay sculpture.
The videos took longer to load than it took to play. -Oh, Youtube. Did you find a model to work with or are you doing all that yourself?
Hello, the skin is removed and modified into a metal exoskeleton, as well as the part where the GPU is set up. The proportion is 100%, so the entire model is remade.
Component After the printing is completed, it needs to be cleaned before UV irradiation and exposure.
Polishing The beginning of a test of endurance , use 600 and 800 grit sandpaper for polishing. Since the parts are small and there are many curved surfaces, the thickness is only 2mm, so it takes more time and energy to process.
Hardware AORUS Z490 XTREME AORUS GeForce RTX 3080 MASTER 10G AORUS P850W 80+ GOLD Modular AORUS RGB Memory 3200MHz GIGABYTE NVMe SSD 1TB COOLER MASTER MASTERFAN SF120M COOLER MASTER ATX 24 Pin 90° Adapter Standard GL ALPHACOOLEiszapfen Laser Fitting With 4pin Molex Water cooling Bitspower
Modify 3D drawing file After the previous file was printed, it was found that there were some problems with the structure, so the new version has been revised, and the part that contains 3D printing needs to be restarted!!! The original metal exoskeleton is a separate part, modified into one body, and then displayed with lines.
Components I am looking forward to combining these parts together! Military aviation connector for cables. VFD display module. LCD. EL light strip. Inductive switch.
Deconstruction table Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing. Repair countertops will include integrated distribution plates. The material will be 75mm, 40mm aluminum pillar, 10mm, 20mm, 30mm aluminum plate and 20mm acrylic
