Scratch Build – Complete ⭐ Cyberpunk 2077 - Deconstruction #CMWS20Finals
Discussion in 'Project Logs' started by AKMod, 24 Sep 2020.
  1. AKMod
    AKMod Modder
    29 Mar 2018
    I hope I have a little more time haha....
    Thank you bro.
  2. AKMod
    AKMod Modder
    29 Mar 2018
    • Deconstruction table
    Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing.
    The design progress is roughly 95% completed.
    The ring scanner will have infrared function, and the machine will move laterally when turned on and off!
    Cheapskate likes this.
  3. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    The whole thing is extremely nice to watch come together - but as someone looking to build their own mantis blade model, I'm especially enjoying seeing yours come together!
    AKMod likes this.
  4. Cheapskate
    13 May 2007
    It's getting really wild and detailed. :D You haven't even added the computer components yet.
    AKMod likes this.
  5. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Molto carino fratello
    AKMod likes this.
  6. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you man.:clap:
    Actually the hardware is already planned on it. :rock:
  7. AKMod
    AKMod Modder
    29 Mar 2018
    • Component
    The touch switch and LCD screen base are completed!
    The upper cover part of the repair table is completed.
    I want to have a hierarchical concept so I used 5mm, 8mm, 10mm acrylic.
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    If there's one and only one good thing to come from Cyber flop 2077 its all these incredible case mods ! Damm i'm even thinking of spraying mine blue and yellow and adding some stickers :p
    This is really next level , it cant even be called a case anymore .. it's more of an amazing display for parts.
    AKMod likes this.
  9. Cheapskate
    13 May 2007
    @def - Right? MOTY 2021 already has a major contender... and the year hasn't started yet.
    AKMod likes this.
  10. AKMod
    AKMod Modder
    29 Mar 2018
    I'm glad you can like it!:clap:
  11. AKMod
    AKMod Modder
    29 Mar 2018
    • Components
    EL light guide plate, used to present the feeling of the product name at the bottom.
    Micro putter, link scanner base.
    Anti-scalding cloth, which will be used to wrap copper pipes.
    Added a control box to place the PCB board, integrate the small parts and include the VDF cold light display.
    Power shield.
  12. AKMod
    AKMod Modder
    29 Mar 2018
    • painting
    These blood vessel paintings took a day hahaha...
  13. AKMod
    AKMod Modder
    29 Mar 2018
    • Component
    CNC 20mm acrylic double-sided processing, 3 stacked decorative props.
    Light guide plate.
    Fan exhaust cover.
    Control box aluminum base plate.
    1.5mm aluminum plate, grooved and bent.
  14. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  15. Cheapskate
    13 May 2007
    There's just so much going on. I'm getting 'fantastic stuff overload.' :lol:
    AKMod likes this.
  16. AKMod
    AKMod Modder
    29 Mar 2018
    • Damage
    The scratch effect of the substrate is completed, and then start to make the details, and finally the overall old surface treatment.
    The primer spraying on the cover of the repair table is completed, and then the top coat is sprayed and the old effect is treated.
  17. censored_Prometheus_
    26 Mar 2019
    Looks fantastic! :jawdrop::jawdrop::jawdrop:
    AKMod likes this.
  18. Cheapskate
    13 May 2007
    This is going to look amazing.
    AKMod likes this.
  19. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks guys. :brrr:
  20. AKMod
    AKMod Modder
    29 Mar 2018
    • Detail
    Refer to some patterns on Mantis Blades, use UV printing and laser engraving to restore the sense of reality.
    Designed some fonts suitable for the theme.
