Scratch Build – Complete ⭐ Cyberpunk 2077 - Deconstruction #CMWS20Finals
Discussion in 'Project Logs' started by AKMod, 24 Sep 2020.
  1. AKMod
    AKMod Modder
    29 Mar 2018
    Hello everyone,
    The theme is Cyberpunk 2077-Deconstruction and will focus on the most eye-catching Mantis Blades in the repair and deconstruction game!
    Specs:
    INTEL I9-10900K
    AORUS Z490 XTREME
    AORUS GeForce RTX 3080 MASTER
    AORUS RGB Memory 3200MHz
    GIGABYTE NVMe SSD 1TB
    AORUS P850W 80+ GOLD Modular
    COOLER MASTER MASTERFAN SF120M
    ALPHACOOLEiszapfen Laser Fitting With 4pin Molex
    ZADAK CAPACITIVE TOUCH SWITCH
    3M TWIN AXIAL PCIe CABLE SH
    Water cooling:
    Bitspower Premium Summit M Mystic Black Metal Edition
    Bitspower D5 Vario Motor
    Bitspower Leviathan XF 120 4xG1/4" Radiator
    Bitspower Water Tank Z-Multi 50 V2
    Bitspower Touchaqua In-Line Filter
    Bitspower Touchaqua Digit Thermal Sensor
    Bitspower Touchaqua Digital RGB Multi Function Controller
    Bitspower Touchaqua PWM FAN Multi Function HUB
    Bitspower Fittings
    Massive thanks to Cooler Master, AORUS, NVIDIA GeForce Taiwan, Bitspower, ModMyMods, ZADAK, 3M for supporting my projects.
    Facebook:https://www.facebook.com/AKModTW/
    Youtube:http://www.youtube.com/c/AKMod
    instagram:https://www.instagram.com/akmodtw/
    MPC likes this.
  2. AKMod
    AKMod Modder
    29 Mar 2018
    • 3D model
    Divided into two parts,
    The first part is a sketch of the base of the repair table,
    The second part is the appearance of Mantis Blades. I removed the external skin and changed it to the concept of a metal exoskeleton.
    Draft computer drawing.
    3D modeling.
    MPC, neSSa and Cheapskate like this.
  3. AKMod
    AKMod Modder
    29 Mar 2018
    • 3D printing
    This time there are about 90 3D printed parts, contains FDM and DLP.
    Make skin mold for clay sculpture.
  4. AKMod
    AKMod Modder
    29 Mar 2018
    • 3D printing
    Ultrasonic cleaning.
    UV lamp irradiation.
    MPC, Cheapskate and ivory2k19 like this.
  5. Cheapskate
    13 May 2007
    :lol: The videos took longer to load than it took to play. -Oh, Youtube.
    Did you find a model to work with or are you doing all that yourself? :jawdrop:
  6. AKMod
    AKMod Modder
    29 Mar 2018
    Hello, the skin is removed and modified into a metal exoskeleton, as well as the part where the GPU is set up. The proportion is 100%, so the entire model is remade.
  7. AKMod
    AKMod Modder
    29 Mar 2018
    • Component
    After the printing is completed, it needs to be cleaned before UV irradiation and exposure.
    douglas alves, neSSa, MPC and 6 others like this.
  8. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Pretty cool! Can't wait to see what it looks like finished with how good the raw parts look already!
    AKMod likes this.
  9. AKMod
    AKMod Modder
    29 Mar 2018
    Slowly updating, thanks.
  10. AKMod
    AKMod Modder
    29 Mar 2018
    • Polishing
    The beginning of a test of endurance :) , use 600 and 800 grit sandpaper for polishing.
    Since the parts are small and there are many curved surfaces, the thickness is only 2mm, so it takes more time and energy to process.
    MPC, Jean R built, ivory2k19 and 2 others like this.
  11. AKMod
    AKMod Modder
    29 Mar 2018
    • Hardware
    AORUS Z490 XTREME
    AORUS GeForce RTX 3080 MASTER 10G
    COOLER MASTER ATX 24 Pin 90° Adapter Standard GL
    • Water cooling
    Bitspower
    neSSa and MPC like this.
  12. MPC
    MPC Minimodder
    24 Oct 2015
    Very good dude !
    I follow with interest :clap:
    AKMod likes this.
  13. AKMod
    AKMod Modder
    29 Mar 2018
    glad you liked it. :clap:
  14. AKMod
    AKMod Modder
    29 Mar 2018
    • Modify 3D drawing file
    Because the game is not yet on the market, the information is very limited!
    After the previous file was printed, it was found that there were some problems with the structure, so the new version has been revised, and the part that contains 3D printing needs to be restarted!!!
    The original metal exoskeleton is a separate part, modified into one body, and then displayed with lines.
    MPC likes this.
  15. AKMod
    AKMod Modder
    29 Mar 2018
    • Components
    I am looking forward to combining these parts together!
    Military aviation connector for cables.
    VFD display module.
    LCD.
    EL light strip.
    Inductive switch.
  16. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Really interesting, i'm curious to see the use of that military aviation connectors!
    AKMod likes this.
  17. Cheapskate
    13 May 2007
    ALL the crazy extras. :thumb:
    AKMod likes this.
  18. AKMod
    AKMod Modder
    29 Mar 2018
    Will be used for MB 24pin 8+8pin and GPU 8+8pin cables
    Thank you bro!:clap:
  19. AKMod
    AKMod Modder
    29 Mar 2018
    • Deconstruction table
    Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing.
    Repair countertops will include integrated distribution plates.
    The material will be 75mm, 40mm aluminum pillar, 10mm, 20mm, 30mm aluminum plate and 20mm acrylic
    MPC, Cheapskate, lowfat and 2 others like this.
  20. keenan
    keenan Minimodder
    12 Nov 2013
    The attention to detail shown here is incredible!
    Absolutely amazing!
    AKMod likes this.
