Scratch Build – Complete ⭐ Cyberpunk 2077 - Deconstruction #CMWS20Finals
Discussion in 'Project Logs' started by AKMod, 24 Sep 2020.
  1. Toru
    Toru Minimodder
    14 Dec 2013
    Super Cool job bro !!:jawdrop:
    AKMod likes this.
  2. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Awesome print and paint job! What are you using to fill up the uneven spots?
    AKMod likes this.
  3. AKMod
    AKMod Modder
    29 Mar 2018
    I was scared hahahaha...
  4. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you bro! :clap:
  5. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks.
    I use plastic steel to fill soil, resin fill soil, water-based, model special soil filling soil fill.
  6. AKMod
    AKMod Modder
    29 Mar 2018
    • Spray paint
    After the sanding is completed, the second primer is sprayed.
    Then you can spray the metal plating primer.
    I am accustomed to stacking the old effects from the inside to the outside to show make real.
    Sanding, filling, primer x2, metal electroplating primer (reducing the bottom layer of the metal exoskeleton), peeling effect paint, metallic white finish paint, scratched aging, acrylic paint aging treatment, transparent protective paint.
  7. AKMod
    AKMod Modder
    29 Mar 2018
    • Distribution plates top cover
    The upper cover uses 10mm acrylic processing, and the surrounding corners are processed.
    Manual tapping.
    Bracket cover
    Cheapskate, Jean R built and Toru like this.
  8. AKMod
    AKMod Modder
    29 Mar 2018
    • Deconstruction table
    Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing.
    The design progress is roughly 80% completed, the concept of repairing and deconstructing Mantis Blades is getting closer!
  9. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Amazing work!:eeek::jawdrop::jawdrop::jawdrop::thumb:
    AKMod likes this.
  10. AKMod
    AKMod Modder
    29 Mar 2018
    • EL light board
    VFD display module is programmed, display number 2077 12 10.
    Jean R built, neSSa and Cheapskate like this.
  11. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks!
  12. Cheapskate
    13 May 2007
    Beautiful :D
    I love all the long and shapely brackets too. I subconsciously avoid stuff like that because it takes extra material. :lol:
    AKMod likes this.
  13. AKMod
    AKMod Modder
    29 Mar 2018
    • Metal aluminum processing
    Some metal processing is completed, and the four tripods look very imposing hahaha...
    I especially found pure copper screws that fit the style.
  14. Cheapskate
    13 May 2007
    Delicious.
    AKMod likes this.
  15. AKMod
    AKMod Modder
    29 Mar 2018
    • Test assembly
    Test the combination of some finished metal aluminum parts with the chassis.
    The ratio is a bit huge hahaha.....
  16. Cheapskate
    13 May 2007
    The stress on the leg screws is kind of scary.
    That looks sooooo good, though.
    AKMod likes this.
  17. AKMod
    AKMod Modder
    29 Mar 2018
    I was worried about the structure at the beginning, so I chose M6 screws to fix it, and the 20mm acrylic through hole was locked down on the 20mm aluminum piece haha...
  18. AKMod
    AKMod Modder
    29 Mar 2018
    • Spray paint
    Metal electroplating paint spraying, restore metal texture,
    then spray the pearl white finish of the metal exoskeleton, and you can start the aging effect after finishing.
    The bracket part is sprayed with metallic iron gray.
  19. AKMod
    AKMod Modder
    29 Mar 2018
    • Spray paint
    This modification involves a lot of spraying operations.
    Mantis Blades primer is completed, start detail processing, masking spray.
    Parts of the repair stand start painting.
    After the rusty inner layer is finished, sprinkle salt and add water!
    Bottom old effect treatment
  20. kim
    kim hardware addict
    10 Jan 2016
    :jawdrop: what a tremendous amount of work in terms of conception, 3D designing, printing and other steps, :wallbash: that's nuts, and totally awesome :clap:
    AKMod likes this.
