Scratch Build – In Progress Cyberpunk 2077 - Deconstruction
Discussion in 'Project Logs' started by AKMod, 24 Sep 2020.
  1. AKMod
    AKMod Active Member
    29 Mar 2018
    Hello everyone,
    The theme is Cyberpunk 2077-Deconstruction and will focus on the most eye-catching Mantis Blades in the repair and deconstruction game!
    Specs:
    INTEL I9-10900K
    AORUS Z490 XTREME
    AORUS GeForce RTX 3080 XTREME
    AORUS RGB Memory 3200MHz
    AORUS NVMe Gen4 SSD 1TB
    AORUS P850W 80+ GOLD Modular
    COOLER MASTER MASTERFAN SF120M
    Water cooling:
    Bitspower Premium Summit M Mystic Black Metal Edition
    Bitspower D5 Vario Motor
    Bitspower Leviathan XF 120 4xG1/4" Radiator
    Bitspower Water Tank Z-Multi 50 V2
    Bitspower Touchaqua In-Line Filter
    Bitspower Touchaqua Digit Thermal Sensor
    Bitspower Touchaqua Digital RGB Multi Function Controller
    Bitspower Touchaqua PWM FAN Multi Function HUB
    Bitspower Fittings
    Massive thanks to Cooler Master, AORUS, NVIDIA GeForce Taiwan, Bitspower, ModMyMods for supporting my projects.
  2. AKMod
    AKMod Active Member
    29 Mar 2018
    • 3D model
    Divided into two parts,
    The first part is a sketch of the base of the repair table,
    The second part is the appearance of Mantis Blades. I removed the external skin and changed it to the concept of a metal exoskeleton.
    Cheapskate likes this.
  3. AKMod
    AKMod Active Member
    29 Mar 2018
    • 3D printing
    This time there are about 90 3D printed parts, contains FDM and DLP.
    Make skin mold for clay sculpture.
  4. AKMod
    AKMod Active Member
    29 Mar 2018
    • 3D printing
    UV lamp irradiation.
    ivory2k19 likes this.
  5. Cheapskate
    13 May 2007
    :lol: The videos took longer to load than it took to play. -Oh, Youtube.
    Did you find a model to work with or are you doing all that yourself? :jawdrop:
