Case Mod - Complete ⭐ CyberPunk 2077 < Tribute Project > #CPBR12
Discussion in 'Project Logs' started by Yury, 22 Sep 2019.
  1. Yury
    Yury Member
    7 Mar 2019
    Hey guys, I'm new to this forum but I've been watching for a long time, I want to leave here the timeline of my last project presented at Campus Party Brazil 2019. I really like futuristic themes and sci-fi, so I chose the new game from CD PROJEKT RED as theme for my project, CyberPunk 2077.
    Special thanks to the supporters of this project: Cougar - Asrock - PlayerID - G9 Laser
    Case: Cougar Conquer Essence
    Peripherals, PSU, and Motherboard
    Cougar CMX 1200w
    Immersed Cougar Headset
    Cougar Deathfire EX Keyboard and Mouse Kit
    Cougar Bunker
    Cougar Arena Mouse Pad
    AM4 Asrock Motherboard
    [​IMG][​IMG]
    First part of the project, create a backplate for the case and add a 14-inch monitor.
    LCD will display PC temperature and consumption information
    To finish this part I mounted the inverted motherboard
    [​IMG][​IMG]
    Hardbox likes this.
  2. Yury
    Yury Member
    7 Mar 2019
    LCD basic test
    Part two of the project, create a cover for the motherboard
    [​IMG][​IMG]
    That was a lot of work, sewing an El Wire thread in text form for the cover.
    Cover finished
  3. Yury
    Yury Member
    7 Mar 2019
    PSU cover construction
    Recreating effect of illuminated wires with orange EL Wire
  4. Yury
    Yury Member
    7 Mar 2019
    Removing GPU Support
    Rebuilding Front Panel
    The front panel will receive a new power button and two OLED displays connected to two arduinos to display specific information such as PSU Watts consumption in real time.
    To measure the consumption of PSU I used this current sensor connected directly to the power supply.
    [​IMG][​IMG]
    PSU successfully hacked HAHA
    Hardbox likes this.
  5. Yury
    Yury Member
    7 Mar 2019
    Time to build a stand for one of the arduinos
    SSD is a gateway to Arduino cables
    Very stylish Arduino cables
    Painting matte black
  6. Yury
    Yury Member
    7 Mar 2019
    Time to make everything golden
    Neither the video card will escape
  7. Yury
    Yury Member
    7 Mar 2019
    Final step assembling all this mess
    A laser cut for the gpu cover
  8. Yury
    Yury Member
    7 Mar 2019
    FINISHED !!!
    [​IMG][​IMG] [​IMG]
    Thanks again Cougar Asrock PlayerID and G9 Laser for believing in my work, taking the opportunity to say that I am already starting another project for 2020 await. A big hug to all and see you later
    Theophilus_Field likes this.
  9. Theophilus_Field
    Theophilus_Field If all else fails... use the surfacing tools
    17 Oct 2013
    :clap: EL Wire!
    Such a great aesthetic, lots of projects add LED's nowadays but I love the cyberpunk combination of neon-esque lighting, satin black and bare metal.
    What did you use to run the side monitor with all the readouts?
    and, is that logo animated :eeek:
    Yury likes this.
  10. Yury
    Yury Member
    7 Mar 2019
    Thank you very much, the screen and a 14 inch monitor connected directly to the computer, Yes the logo is lively as all the rest of the information is real, I used the AIDA64 monitoring software it allows you to create a custom HUD with any information that you have. the software owns over your hardware.
  11. Yury
    Yury Member
    7 Mar 2019
