Case Mod - Complete CYBERPUNK 2077 XBOX TRIBUTE CASEMOD
Discussion in 'Project Logs' started by pccustom, 11 May 2022.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    hi guys start a new adventure thanks to the sponsors stay tuned
    CASE: AZZA CAST
    MOTHERBOARD: ASROCK B560 PRO4
    RAM: OCPC EXTREME 32 GB KIT
    STORAGE OCPC M.2 NVMe 512 GB
    COOLING: CUSTOM LOOP EKWB
    GPU: MSI GEFORGE RTX 3060 VENTUS 12 GB
    CPU i5 11600K
    PSU: AZZA 650W ARGB [/align][/align]
  2. pccustom
    12 Jul 2017
    video presentation of components and sponsors
    4LIEN, kim and Dot_Kappa like this.
  3. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Nice case :naughty:
    I'm in...please proceed :dremel:
    pccustom likes this.
  4. Cheapskate
    13 May 2007
    Wait. :worried: Did you get a new work surface, or is that the kitchen mat?
    Defyant Mods likes this.
  5. pccustom
    12 Jul 2017
    well guys until you get your hands on you don't realize the situation ..
    first impressions and considerations on this case, the panels that cover the central structure are in aluminum, the central part of the case is of excellent 1 mm thick steel,
    very robust and heavy case, I would have expected to have the 3 front fans that strananente are not included in the case ...
    small flaw of azza in my opinion I had to have them shipped in a 4-piece retail package.
    This mod will mount a custom loop for the cpu, the video card will be mounted at 90 ° I leave it as it is, and a self-built tank, everything must be visible without necessarily having to open the top panel as already seen in many photos of others modders and builders, this original case would be fine for a build but for a mod it has to be more in plain sight for this reason, after a careful evaluation,
    I deplored to make some cuts but following the typical lines of cyberpunk, others will be highlighted by the various additional acrylic panels ..
    let's start with a nice cut ....
    now in realy better!
  6. pccustom
    12 Jul 2017
    cover panels, will cover the whole case.
  7. Cheapskate
    13 May 2007
    I just knew there would be plastic. :D
    The_Crapman and pccustom like this.
  8. pccustom
    12 Jul 2017
    plastic forever...:)
  9. pccustom
    12 Jul 2017
    completing up and sides panels
    Cheapskate likes this.
  10. pccustom
    12 Jul 2017
    almost finished case covers ..
    other panels will be further processed like these.
  11. pccustom
    12 Jul 2017
    frontal panel
    all the other panels will undergo the same processing subsequently application of the graphics ..
    Dot_Kappa and Cheapskate like this.
  12. kim
    kim hardware addict
    10 Jan 2016
    Like someone said already, it's impossible to spot if it is CNC machined out of metal or hand made out of acrylic, but what is sure is that you're an incredibly talented modder :wallbash:
  13. pccustom
    12 Jul 2017
    thank you very much KIM you have kind words, but believe me if I tell you that everyone can do this, you just need to have passion and time ..
    kim likes this.
  14. Cheapskate
    13 May 2007
    Time being the tricky part to acquire...
    Looking great, as always.
    pccustom and Dot_Kappa like this.
  15. pccustom
    12 Jul 2017
    here we are guys SAMURAI side panel
    sanding scratch effects
  16. Cheapskate
    13 May 2007
    Awesome! :D
  17. pccustom
    12 Jul 2017
    even the lower and upper movable panels have been completed still missing the classic XBOX graphics
    the front panel has been partially completed with logos
    Monkey Puzzle and Cheapskate like this.
  18. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Eye candy! :dremel::dremel::dremel:
  19. Cheapskate
    13 May 2007
    It feels like that happened faster than normal. :lol: They look perfect.
  20. Dot_Kappa
    23 Mar 2006
    Samurai panel is my favourite one :jawdrop::clap:
    Is there a final layer with clear matt paint ?
