Case Mod - Complete CYBERPUNK 2077 XBOX TRIBUTE CASEMOD
Discussion in 'Project Logs' started by pccustom, 11 May 2022.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    YEs..
  2. pccustom
    12 Jul 2017
    Hi guys all the panels are completed application of the graphics,
    I recreated most of the console graphics thanks to a friend of mine who physically having it He took pictures of the details and I recreated them in Abbe ìllustrator,
    being the houses much larger than the console I had to recreate new graphics to cover all the chassis I have scored others ...
    Further worn effect ..
    now I get everything back ..
    Now the case is completed I think I approached the theme Next step interior setting, creation of the internal panels, creation of the tank, passcavi, and studying a decent custom loop I keep on the simple ..
  3. Cheapskate
    13 May 2007
    That's a lot of eye-candy for one post. :D Beautiful!
    pccustom likes this.
  4. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Amazing building talent you have mate. :thumb:
  5. pccustom
    12 Jul 2017
    here we are, now that the outer case is completed, all that remains is to assemble the inside ..
    I realized that the bracket that mounts the GPU vertically is too long and gives problems to the tank ..
    this is because the case nin is very big ..
    no problem we shorten ..
    all I do is remove the part that hooks the case
    once the affected part has been broken down,
    I remove the excess I build another element that will hook onto the case holding the original structure together as well as giving a nice look and staying in theme with the mod ..
    perfect..
    construction of tank and overall dimensions
    once dried I do a seal test ..
    frame construction, I have yet to decide the color
    I'd say we're here now ...
    kim and Cheapskate like this.
  6. pccustom
    12 Jul 2017
  7. kim
    kim hardware addict
    10 Jan 2016
    Neat :rock:I'm so amazed of these home made water-tanks, I use the plurial because it's not your first one... they look as perfect as if EK made them themselves:jawdrop:
  8. pccustom
    12 Jul 2017
    RGB gpu side panel besides the function of hiding the metal parts, it has a remarkable aesthetic function, what do you think? excellent anodized screws of cablemod ... perfect ...
  9. pccustom
    12 Jul 2017
    unscheduled panel, it will serve to cover the sheet metal cover of the case which, in addition to containing the cables, also supports the pump ...
    the tank is finished
  10. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    As an old modder using these techniques 20 yrs ago and seeing how they still hold up in todays modern wold of let a keyboard and machine do all the work for you modding scene it warms my heart . Hand skills will always reign supreme imo :D
    Dot_Kappa, kim and pccustom like this.
  11. kim
    kim hardware addict
    10 Jan 2016
    Totally ... It warms my heart too, as an old "modding enthousiast" myself :grin:, following the modding scene almost from the first years, (including your former mods here :grin:) ...and still not bored nowdays curiously :geek:, I can't deny, there're amazing mods made out partly or fully with some machined or 3D printed parts (you can't disagree on that point :grin:), and this is a great breakthrough in the field of modding, but I agree, nothing compared to hand skills ...long may it reign :rock:
    Defyant Mods, Dot_Kappa and pccustom like this.
  12. pccustom
    12 Jul 2017
    Covering/support pump support .. Painting I used this cover to fix the pump and hide excess cables since this power supply is not modular ..
    applied graphics
    Custom loop completion- nothing complicated ..
    All that remains is to reassemble the GPU with me its modified support Install the Drivers operating system..Itage speed of the pump ... the usual things..stay tuned for the final photos ... and this is also done ...
    Cheapskate likes this.
  13. The_Crapman
    5 Dec 2011
    Plastic surgeon extraordinaire
    pccustom and kim like this.
  14. Cheapskate
    13 May 2007
    COOOL! The text on the res lights up too, right?
    Looking now, I realize the fillport is at the bottom of the loop. That must have been tricky to fill.
  15. pccustom
    12 Jul 2017
    at this moment no other led in addition, what you see is the bleed, the topping up is at the top but it was difficult to fill even from there ..
  16. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    Beautiful! Well done - looks amazing!
  17. pccustom
    12 Jul 2017
    well guys we have reached the end of this project as always a big thank you to all the sponsors who have allowed it azza, asrock, ocps, ekwb, cablemod, microtech, hwlegend modding a special thanks to my friend FEDERICO from technodummies who, having this console, provided me with the photos to be able to replicate the logos
    I leave you his interesting channel
    https://www.youtube.com/channel/UCspIRowO3CgCqyf9o2c22fA
    but let's start with the roundup of photos ..
  18. Cheapskate
    13 May 2007
    Nailed it.
    I looks like an in-game object, or prop for a movie adaptation.
  19. kim
    kim hardware addict
    10 Jan 2016
    The original case looks dull compared to your design :grin:
    :clap:really beautiful, and it's always a pleasure to follow your work :rock:
  20. pccustom
    12 Jul 2017
