Scratch Build – In Progress CYBERPUNK 2077 YAIBA KUSANAGI scratch build handmade SPONSORED *HWLEGEND MODDING TEAM* CMWS2020
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. pccustom
    pccustom Well-Known Member
    12 Jul 2017
    next mod coming soon I could not miss this new project another adventure begins.
    thanks to my sponsors
    ASROCK, INNO3D, CRUCIAL, SEASONIC, EKWB, HARDWIRE, COOLERMASTER, PC HUNTER
    configuration
    motherboard asrock Z390M PRO 4
    cpu intel core I7 9700KF
    gpu inno3d geforce rtx 2080 super twin x2 oc
    cooling EKWB custom loop
    crucial memory ballistix max 32 gb kit
    crucial memory ssdmx500 x2
    crucial memory M2 1TB P1
    psu seasonic prime PX850W
    cable mod hardwire
    addictional fan coolermaster 200 MF R RGB​
    ciaognep and MADPC like this.
  2. ciaognep
    ciaognep Member
    10 May 2020
    oh man....another beauty :)
  3. djlegend
    djlegend Member
    9 Jun 2015
    I follow the mod with interest.:happy:
  4. zogthegreat
    zogthegreat Member
    10 Sep 2011
    OK, I have the popcorn ready! What's next?
  5. ivory2k19
    ivory2k19 Active Member
    8 Feb 2019
    I'm excited to see what you present us :dremel::clap:
  6. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Ah ahh, another scratch-build.... I'm in man :clap:
  7. 4LIEN
    4LIEN Active Member
    4 Jan 2020
    I will follow the project also here!
  8. pccustom
    12 Jul 2017
    first stock of ekwb material arrived
    a lot of material but the eye only falls on 2 elements
    the massive waterblock for the RTX 2080 and the CPU block VELOCITY
    Let's starts ..
    ivory2k19 and 4LIEN like this.
  9. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    What a porn hardware exposition. Impatient to see next steps !
    YOU Never stop ?! :dremel:
  10. pccustom
    12 Jul 2017
    the dances begin now that I have most of the material at hand I can evaluate the dimensions ...
    I start from aluminum strips to build the side frames, a very delicate operation, so both must be extremely precise, maximum precision
    I try to be faithful to the sketch created (which I don't show you ...) one eye on the render and one on the hardware, I cut ..
    it is not at all easy to make them the same once you have made one proceed with the second by placing it on the first.
    as already done for black hawk silt slightly the heads of the rivets this because could annoy the insertion of the side panels.
    next step to consolidate the structure with steel tubulars between the 2 frames.
  11. censored_Prometheus_
    censored_Prometheus_ Active Member
    26 Mar 2019
  12. pccustom
    12 Jul 2017
    today I focus on the lower part, power supply housing, construction of the supports that will support the shock absorbers
    those who know me from the beginning know that I like to recycle parts of disused PCs near the landfill, today it has been the turn of an old HP the sheet is incredibly thick and robust
    cut and shape that interests me.
    these supports are very important because as mentioned, in addition to housing the shock absorbers, they will also support the acrylic bars to close the structure on the back
    more forward you will be all clearer ..
  13. Canardwc
    22 Sep 2011
    Yes, no more ad, just modding :winking:;) :thumb:
    I follow !!!
  14. pccustom
    12 Jul 2017
    today 3 steps
    I had already prepared the support for the power supply unit but I was not happy and did not allow for excellent heat dissipation.
    everything is designed in such a way that its replacement or removal is also easy
    realization of the supports for the positioning of the tank and integrated pump these strips will further strengthen the structure which is not yet stable
    as we proceed, everything will consolidate.
    EKWB also provides an adhesive where to make the holes very comfortable, all time saved.
    I also drill holes on the opposite side with a larger diameter so that they can be accessed with the fixing screws
    addition of upper lateral slats for fixing the entire rear part which will be made of 4 mm acrylic panels with lamellar effect ...
  15. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    Looking amazing as always :rock: I love the designs you come up with for your frames :thumb::dremel:
    Canardwc and pccustom like this.
  16. ciaognep
    ciaognep Member
    10 May 2020
    sir ... you have not posted the initial rendering as in black hawk, so we knew what to know about it, but here friend, it is really a big surprise, the work starts great !!! you are a manual and conceptual artist ...
    pccustom likes this.
  17. pccustom
    12 Jul 2017
    thank you!!!
  18. ivory2k19
    8 Feb 2019
    Amazing work :jawdrop::dremel:
  19. pccustom
    12 Jul 2017
    processing of the rear part which will consolidate the whole structure the panels are temporary, the tray for the motherboard (on which other panels and supports will be mounted) and for the vertical video card are still missing.
    I do not rule out making other changes during the work.
    I preferred to stay a bit wide with the measurements I am always in time to cut if I need ....
    Just like I do a cardboard sample to do the various tests
    when I am quite sure I proceed with the various cuts on acrylic.
    I did the first and I use it as a "master" for all the others, they must be perfect .... at least I try.
    all done by hand.
    after taking the right measures I assemble everything
    the panels that will make up the rear will have thicknesses (now there are not) that will keep them tight and the structure will be more solid.
  20. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    This is looking awesome so far :dremel::rock:
    Defyant Mods and pccustom like this.
