Scratch Build – In Progress CYBERPUNK 2077 YAIBA KUSANAGI scratch build handmade SPONSORED *HWLEGEND MODDING TEAM* CMWS2020
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. pccustom
    pccustom Well-Known Member
    12 Jul 2017
    118 / 5000
    Risultati della traduzione
    with the work I went a long way, but I don't have the time to post more photos, the cmws20 deadline is near ...
  2. pccustom
    12 Jul 2017
    the work was a lot I did not have time to post new photos but here is the work at what point it has come. let's take care of the memories
    intel i7 9700kf 3.6 ghz 12 mb cache processor installed by PCHUNTER
    led assembly
    200mm master cooler fan
    360 mm radiator positioning with 6 fans, 3 in and 3 out
    waterblock ek mounting on INNO3D RTX 2080 TWIN X2 video card
    waiting for the cable riser cooler master to arrive I do some tests, it fills well ...
    EK combo positioning on the top
    processing and conclusion of the lower panel
    processing and conclusion of the lower panel...
    lower casing that will contain the controller of fans and rgb lights of the whole case.
    positioning of lights on the support of the internal panel.
    positioning of lights on the support of the internal panel. completion of the internal panel and graphics
    And it's not over yet... :)
  3. lowfat
    lowfat Active Member
    4 Jul 2013
    Hot damn that Samurai logo looks ridiculous.
  4. Cheapskate
    13 May 2007
    ALL of it looks ridiculous. :clap:
  5. pccustom
    12 Jul 2017
    I'm afraid I don't understand ...
  6. Cheapskate
    13 May 2007
    The project is so amazing that it is crazy.
    Defyant Mods likes this.
  7. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    "Ridiculous"..... meaning amazing what you come up with :rock: Those blades at the back remind me of RGB memory sticks :naughty:
  8. pccustom
    12 Jul 2017
    ah ok, Ridiculous in Italian means different, so I didn't understand .. thanks :)
  9. pccustom
    12 Jul 2017
    CPU waterblock customization seemed right to stay on topic ..
    arrivato il riser cooelrmaster..
    mounted the ek waterblock on the inno 3d rtx 2080 super twin x2
    ready for the custom loop ...
  10. Cheapskate
    13 May 2007
    It means the same in English. It was used as slang earlier.
    We all really love the build. It just doesn't translate sometimes. :D
    pccustom likes this.
  11. pccustom
    12 Jul 2017
    thank you cheapskate!!
  12. pccustom
    12 Jul 2017
    nstallation of the 7 "monitor on the front panel.
    front panel buttons ..
    improvement of the internal panel I add more plexi underneath to enhance the lighting.
    preparation of external logo panels
    ssd covers
    cut-out panel cover psu that will contain all the cables..serve for the pipes
  13. Defyant Mods
    14 Sep 2004
    All the small fortunes ppl spend to impress on modding sites and you kik their asses with just your hands skills and imagination..... :dremel:
    This is CRAZY RIDICULOUS :rock::rock::rock:
    kim likes this.
  14. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    whoa thats some sexy eye candy! The painting, and high accuracy on manual building/cutting/bending continue to amaze :rock:
