Scratch Build – Complete ⭐ CYBERPUNK 2077 YAIBA KUSANAGI scratch build handmade SPONSORED HWLEGEND MODDING TEAM #CMWS20Finals
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. 4LIEN
    4LIEN Modder
    4 Jan 2020
    OMG! Beautiful! :eeek:
    pccustom likes this.
  2. pccustom
    pccustom Multimodder
    12 Jul 2017
    YAIBA TO ALL! today a lot of work, I leave the rear part suspended to focus on the front, I make a panel of solid recycled steel from my HP desktop, the metal structure of these old houses is really impressive solid and thick sheet metal, the empty case already has its considerable weight.
    here it is
    to install the 360 mm radiator I need supports but at the same time I need to strengthen the structure, let's start ..
    measurement control and positioning ...
    now the most interesting part
    I finish with precision files always checking the measurements
    I am very satisfied with the result considering that I have no specific equipment and I made everything with basic tools
    and if I can do it, anyone can do it. :)
    check that everything concludes.
    fastening with rivets, I always check the measurements
    the structure is now much more solid and stable.
    to be continued---
    Wufoz, Cheapskate, 4LIEN and 2 others like this.
  3. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Recycling !!! All I love...!!!
    Nice clean work :clap:
  4. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Who need a CNC if you can craft it. :dremel:
    Nice work i like it :thumb:
  5. MADPC
    MADPC Minimodder
    10 May 2020
    great great great work :clap:
  6. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    They just keep getting better!!!
  7. pccustom
    12 Jul 2017
    a lot of work today ...
    processing of the tray, very important as it is an integral part of the structure
    technical dimensions tests
    positioning of the bracket that will fix the inno3d RTX2060super TWIN X2 video card vertically, here helps me coolermaster who sends me a special bracket designed for his houses but that is fine for what I need
    but it's not over I have to find a way to fix it firmly to the panels.
    motherboard placement and holes
    I have an envelope full of spacers I always take them apart before I get rid of an old case
    creation of the hole on the tray to facilitate the installation of the fixing plate for the CPU waterblock
    once you have decided what to do, prepare all the holes for the gpu support bracket
    after taking the measurements well 3 times I proceed
    I practice very small holes
    one points it as a cutter and patiently floods all the holes connecting them creating a groove
    I help myself with a precision file (one of my best purchases)
    perfect..
    it is not yet finished all the tray block must still be well worked .. and the panels made previously must be revised (they are too large)
  8. ivory2k19
    8 Feb 2019
    Just wow :jawdrop:
    How did you cut the plexiglass?
  9. pccustom
    12 Jul 2017
    not all parts can be cut in the same way, generally I use a motorsaw dremel, but I also use a normal hacksaw and sometimes a sharp hook with which I engrave the plexiglass up to cut it, in some cases I use a "rasp" wood file to consume the excess one and then I finish with 220 sand paper.
    ivory2k19 likes this.
  10. BHB Mods
    BHB Mods Minimodder
    15 Jun 2020
    This will look beautiful once done. Love your craftmanship!
  11. pccustom
    12 Jul 2017
    thank you soon updates..
  12. pccustom
    12 Jul 2017
    rear panel added reinforcement elements
    I will add 2 more "sandwich" wings with leds in the center 2 acrylic panels painted with another acrylic panel with leds in the center
    in addition to strengthening the structure, it will have an aesthetic value, 2 D-RGB strips inside these fins
    4LIEN, BHB Mods, ivory2k19 and 2 others like this.
  13. Defyant Mods
    14 Sep 2004
    Loving the stance this has already!!! Jeesus even i don't do that much plex cutting by hand.... It's a testament to how much time you have to spend on these builds! :rock:
  14. pccustom
    12 Jul 2017
    thank you so much!!
  15. Caldiera
    Caldiera What's a Dremel?
    2 Jul 2020
    This Is Amazing!! Cant wait for the next Update!
  16. pccustom
    12 Jul 2017
    thank you--
  17. pccustom
    12 Jul 2017
    completion of the 2 rear led panels
  18. BHB Mods
    BHB Mods Minimodder
    15 Jun 2020
    I love how you're working with acrylic plastic! Really got some inspiration! ❤
  19. pccustom
    12 Jul 2017
    after a short pause he resumes
    creation of the arms with front and rear shock absorbers 150 NW more than enough to support
    the whole structure
    guest of the day christened PISELLINO.
  20. pccustom
    12 Jul 2017
    FEET
    mounting brackets on the frame
    holes for fixing the shock absorbers I leave a little bit of play so they can be adjusted
