Scratch Build – Complete ⭐ CYBERPUNK 2077 YAIBA KUSANAGI scratch build handmade SPONSORED HWLEGEND MODDING TEAM #CMWS20Finals
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    SURE !!! enjoy it!
    ivory2k19 likes this.
  2. Flux
    Flux Minimodder
    11 Jul 2020
    This is so cool!
    pccustom likes this.
  3. pccustom
    12 Jul 2017
    well guys i had to spend some time figuring out how to glue different materials but i solved.
    I have to recreate this effect but without using 3d printing or cnc how to do?
    now I create another support that will follow the top profile now it's easy i have a base now ..
    perfect fit
    I need a structure already made to fix and here comes this to my mind ...
    a salad bowl ..
    I try to find the area with the right inclination and cut leaving what I need
    fixed provisionally
    now the problem is how to fix the 2 different materials together the circle is polypropylene while everything else is in plexiglass, the two materials do not seem compatible with common glues
    I have liquid steel I try with this ...
    seems to hold very well.
    perfect I would say
    now it's the turn of the actual "turbine" support I take the exact measurements of the piece and cut with the DREMEL
    I have to strengthen the whole structure polypropylene is an ugly beast, I solved it temporarily with liquid steel but I need something more dense and workable, the parts to be glued are many and they must not come off
    after several researches I land on this .. a two-component fiberglass putty ...
    I must say once it hardens it becomes concrete and is perfect, even if it weighs down the structure a lot.
    now it's time to complete with the side element
    I take the measures well fixed procvvsoriamente with glue for methacrylate and after the ditch all with workable putty
    well fixed with other putty on the main structure
    it will take other small tweaks such as closing some small holes or making some parts smoother, but the bulk of the work is done
  4. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Exellent work!!! :dremel:
  5. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Really amazing work!
  6. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :jawdrop:
    "simple" custom fan cover :grin:
  7. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    Really great I’m looking forward for the progress to come
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Fantastic work :thumb:
  9. Flux
    Flux Minimodder
    11 Jul 2020
    This looks great!
  10. pccustom
    12 Jul 2017
    thank you guys!!!
  11. pccustom
    12 Jul 2017
    I decided to create a led motherboard tray with relative I / O cover always with leds and themed mod cyberpunk 2077 !!!.
    This tray will be fixed to the support of the case that originally had to support the motherboard, but also given the need to build other parts I decided for this solution
    I start making the I / O panel from scratch, this motherboard does not have one more reason to make it, all the heatsinks of this Z390M PRO4 sponsored by ASROCK will also be painted with a theme! ..
    I trace all the dimensions from the original shield.
    a lot of patience but the result satisfies me ...
    I took my time and calmly the result came, everything fits together perfectly, measured and measured again many times ..
    this tray will substantially consist of two parts, the I / O box and another piece of acrylic left transparent inside on the long side, inside a led strip will be placed that will shoot the light through this acrylic giving a pleasant effect ... the logo will also be illuminated on the top of the box.
    I fix everything with cyanomethacrylate glue but I will strengthen everything with other strong glue and putty to eliminate imperfections.
    coat of primer to see where to stick to close any holes ..
    ready for the final paint job that I will do next, the paints have yet to arrive in the shop ..
    now let's start with the support
    I will drill the holes to pass the cables directly on this support
    so I mark the zones .. I work absolutely with precision if I'm wrong I have to redo the whole panel ... I would not be happy ..
    the hole for the cpu waterblock will also be made
    well guys stay tuned because there will be some good ones ...
  12. Yargen
    1 Aug 2020
    Great work, I really like your idea for the mainboard cover
  13. Defyant Mods
    14 Sep 2004
    That IO cover is such a cool idea:rock:
  14. DB Custom Towers
    DB Custom Towers Just a woman interested in art and PCs
    30 May 2020
    Great idea for the IO cover. I too was going to have my mb try light up with designs but since the motherboard has a light panel behind decided not to and just to have my psu shroud light up. Can't wait to see it all come together. Keep up the great work!:clap:
  15. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Wow great work!!! :dremel::jawdrop:
  16. pccustom
    12 Jul 2017
    continue with the processing of the LED tray, the sleeved cables will pass through the structure
    cover panel that will be painted in metallic red, the prevailing color of our yaiba
    here the explanatory video but it's not over stay tuned ...
    [VIDEO]
  17. DB Custom Towers
    30 May 2020
    did you make the 24 pin template yourself? Good stuff!!!
  18. pccustom
    12 Jul 2017
    yes it's easy.
    DB Custom Towers likes this.
  19. pccustom
    12 Jul 2017
    hi guys, I proceed on other fronts
    support arrangement to fix the I / O cover on the motherboard I take advantage of a screw already present on the motherboard
    supports for fixing the panel steel rods cut with a threaded pipe cutter for M3 screws
    lower "fairing" cover panels and grille fixing for the 200 mm fan
    this side will be quite complex because there will be plates that will be overlapping
  20. pccustom
    12 Jul 2017
    hello everyone, I state that I am speeding up the processing of this mod because the work is so much,
    today is the turn of the front covers ...
    as I always do I start with a cardboard template to see the overall dimensions and folds I can cut and redo as I wish until the result is satisfactory
    only when I'm sure will I cut the acrylic
    after this I proceed with the cut
    finishing and measurement control
    now I will make cuts because part of the panel must not bend but remain straight and have no marks
    I could have done some additional covers but visually it would have been too heavy at the sight of the front design.
    well now there is the most delicate part the bending, I use a self-made bender that I use in all my mods
    this one
    place bits of metal there where I don't want the bender to leave heat marks
    and here it is all went well.
    these little unfolded bits will allow me to hide the ugly to see shock absorber hooks.
    and here they are assembled, they still need to be well finished
    see you soon guys.
