Case Mod - In Progress CYBERPUNK 2077 YAIBA KUSANAGI scratch build SPONSORED *HWLEGEND MODDING TEAM* CMWS2020
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. pccustom
    pccustom Well-Known Member
    12 Jul 2017
    additional rear brackets are required
    I believe that the direction I have taken is now clear :)
  2. 4LIEN
    4LIEN Active Member
    4 Jan 2020
    Absolutely fantastic!
    pccustom likes this.
  3. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    Ive never seen a modder get such amazing value out of a single material ! what you do with hardware shop alu is amazing :rock:
  4. pccustom
    12 Jul 2017
  5. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I am surprised by the shocks' position and the way you are working with them.
    Your are proving that with simple tools but great effort and commitment it's possible to make amazing creations!! :rock:
  6. ivory2k19
    ivory2k19 Member
    8 Feb 2019
    Amazing work!! :jawdrop:
    How did you bend the aluminum?
  7. pccustom
    12 Jul 2017
    I have not folded aluminum but everything is held together by rivets and screws, but you can simply fold aluminum and steel by favoring a small groove with a very straight dremel and then folding it very easily even with your hands.
    ivory2k19 likes this.
  8. kim
    kim hardware addict
    10 Jan 2016
    I am impressed by how you continue to innovate and doesn't cease to renew in originality :jawdrop::wallbash::clap:
  9. pccustom
    12 Jul 2017
    thank you kim!
  10. pccustom
    12 Jul 2017
    Arrangement of the pigtail, as it is I don't like it is too linear to the frame
    an indentation must be created and the fairing will have a fold therefore a more dynamic design.
    First I evaluate where to cut
    cutting little material will allow me to tilt the aluminum easily
    just enough to achieve the desired effect, I end up fixing an aluminum bar with rivets and the structure is very solid
    a little trick that makes the difference in the overall design.
  11. Defyant Mods
    14 Sep 2004
    Very on point :rock: I'd love to start seeing you weld these frames:dremel: Your bends and rivots are amazing work. :thumb: But the frames them selves are the true work of art here :jawdrop: not the plex.
    Welding and then filing to a perfect finish would be next level :rock::rock:
  12. pccustom
    12 Jul 2017
    thank you I don't have a welder and I can't do this service from others it would cost me too much, so I have to do this with an economic but robust method, rivets and screws are the best thing, I'm glad you like my mod but believe me I don't do anything special in 2012 the mods were made like this with rivets and putty for the bodywork, many have forgotten this, I follow your Hyper Case DM-01 I must say that it is unsurpassed is for me a point to follow for my next projects, I will ask you something in process that you used .. :)
    Defyant Mods likes this.
  13. Dot_Kappa
    23 Mar 2006
    Old but gold if well done :cooldude:
    pccustom and Defyant Mods like this.
  14. pccustom
    12 Jul 2017
    small reinforcements added to stabilize the structure
    as well as reinforcing they will be an excellent decorative element
    the fabulous EKWB EK connect controller has arrived in addition to the classic functions
    there are as many as 3 excellent temperature sensors coupled with EK Vardar X3M D-RGB fans
    here the unboxing
    [VIDEO]
    [VIDEO]
  15. pccustom
    12 Jul 2017
    well guys we proceed, this is the turn of the crankcase / turbine of the bike it will be a grill and under it I will put a 200 mm RGB fan
    but how to make it happen? I invent something ...
    fixed with adhesive for temporary acrylic after I will apply a more powerful one to consolidate everything.
    to make a perfect hole I build a tool, dremel has been supplying it for years I don't want to spend 30 euros for a piece of iron and plastic.
    so I decide to find it myself, I take advantage of the supplied cutter support.
    This bar is usable on any mini tool.
    here the project.
    that's where I'll make the hole.
    thanks to coolermaster for providing me with this magnificent rgb coolermaster fan with awkward dimensions .. well 200 mm
    a big beast ... that's where it will go.
    here a brief unboxing ...
    technical positioning tests
    let's go ...
    here it is at work .. the bar behaves well is very smooth you have to proceed very slowly
    as the pieces of acrylic tend to melt with the heat blocking the tip.
    clean from the chips generated every now and then ..
    use the 3d printer because I don't have it.
    but as usual I will try to do something beautiful and above all that costs little ...
  16. kim
    kim hardware addict
    10 Jan 2016
    And beautiful it is :eeek: :rock::dremel:
  17. Defyant Mods
    14 Sep 2004
    That is soooo cool !:rock::rock:
  18. Yargen
    Yargen New Member
    1 Aug 2020
    Really impressive work. I love the way you are taking with the mod
  19. pccustom
    12 Jul 2017
    thank you guys!
  20. ivory2k19
    ivory2k19 Member
    8 Feb 2019
    Nice tool, I saw your video on Instagram with it. I should make myself one too if that's okay for you? :idea:
