Scratch Build – In Progress CYBERPUNK 2077 YAIBA KUSANAGI scratch build SPONSORED *HWLEGEND MODDING TEAM* CMWS2020
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. ivory2k19
    ivory2k19 Member
    8 Feb 2019
    You have some nice tools first the dremel stencil and now the bender :rock:
    pccustom likes this.
  2. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    this looks interesting. i like that you are hand making the acrylic parts and made your own bender too. i made one years ago too which i still use,
  3. pccustom
    pccustom Well-Known Member
    12 Jul 2017
    Thank you!!
  4. pccustom
    12 Jul 2017
    hi guys a lot of work today, as always I specify that all the pieces are hand-worked duqnue without the use of cnc or laser cuts
    well as always happens to me I redo the feet that I don't like them anymore so FEET 2.0 let's go !!
    I studied a design that goes well with the rest, I take the curves and corners of the case
    I prepare the threaded spacers to be inserted between one element and another.
    once tested, finished, sanded and double checked, I proceed with the assembly
    the elements overlap interspersed with data that I use as thickness and the cylinders previously cut and threaded
    if I wanted to widen the base of these feet all I have to do is insert more thick bolts on the external ones, but I will decide later.
    here it is concluded, obviously they will be inserted in the lower part of the anti-vibration rubber and painted in matt anthracite gray with metal signs, like other elements of the yaiba
    I just have to try them on the case to verify the stability and the visual effect.
    the trim has risen a few centimeters I don't mind also because another cover panel will be inserted under the case to emulate the engine bumper
    See you soon!!
  5. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    As always amazing work :rock:
  6. pccustom
    12 Jul 2017
    thank you so much!!! :)
  7. MADPC
    MADPC Member
    10 May 2020
    oh man..... I lost something in long period of absence,,, this is amazing!!!
  8. pccustom
    12 Jul 2017
    it continues without respite I work is a lot and time is running out ..
    today preparation of the side covers of the support arms, let's start ..
    I got a cardboard template to calculate how the piece will be made, after many cuts and resizing here are the parts to cut out and fold on the acrylic.
    still some small improvements and we are ..
  9. WarrenJ
    WarrenJ Well-Known Member
    14 Oct 2009
    Really enjoying seeing this mod come together, great work and excellent craftsmanship. Looking forward to seeing the final result
  10. pccustom
    12 Jul 2017
    today technical tests on color.
    I finish the new feet by painting them with matt anthracite and then with a solvent silver finish.
    no doubt about the talken products, even if they do charge, they are always at the top.
    I help myself with a rag soaked in silver and slowly I do nothing but follow the edges and go over them if they are not sufficiently defined.
    but now i can't wait to try this one
    to be precise, the color of the yaiba kusanagi is a non-metallic anodized red even if this paint is the most similar and is more available on the market, the metallic paint has crystals that reflect the light
    the color changes according to the reflected light.
    this is I / O prepared previously.
    also on here I will pass the silver to simulate the erosion.
  11. Defyant Mods
    14 Sep 2004
    It's the attention to detail of the small things that make a mod a great mod :rock:
  12. pccustom
    12 Jul 2017
    today we proceed with the completion of the rgb i / o panel previously painted in metallic red
    creation and application of decorative elements and ARGB leds
    matt anthracite paint
    here you can find all the processing steps
    ARGB in action
  13. rchiileea
    rchiileea Active Member
    11 Jan 2008
    saw this in another palace and had to come say this is lurvely, I I 100% appreciate the hardwork that goes into getting that worn look to items, I would say creating a worn look is much harder than creating a nice perfect look painting wise, keep it up fellow Cyberpunk builder ;)
  14. pccustom
    12 Jul 2017
    th
    thank you!
  15. pccustom
    12 Jul 2017
    It is with great pleasure that I announce the addition of a new SHARKOON sponsor
    who sent me these two spectacular peripherals that will be modded in cyberpunk 2077 yaiba kusanagi theme
    let's talk about the SGK4 skiller rgb gaming keyboard and the SGM1 rgb mouse
    here the unboxing
    [video=youtube_share;h9-ao2W_tro]
    ivory2k19 likes this.
  16. pccustom
    12 Jul 2017
    the led tray is finished use the small but very efficient ARGB 5V EKWB led strips
    we were left to the construction of the 2 panels today painting of the upper panel installation of the leds and test
    the metallic red to get as close as possible to the one in the sample is necessary to give a coat of white, with primer primer it tends to darken because this metallic color is not completely covering.
    now the underside
    white also serves to make the light extend better on the acrylic
    I take this opportunity to paint even the motherboard and M2 heatsinks
    since there are .... also some covers of the case.
    here is the finished tray ..
    for the most demanding small video with music ....
    [VIDEO]
  17. djlegend
    djlegend Member
    9 Jun 2015
    Very good!
  18. kim
    kim hardware addict
    10 Jan 2016
    Fantastic craftmanship :jawdrop:
  19. Yargen
    Yargen New Member
    1 Aug 2020
    Really impressive, it´s getting better and better. I love it :)
  20. Defyant Mods
    14 Sep 2004
    Very Very Sexy!!! :rock::rock:
