Scratch Build – In Progress Cyberspace - Evolution (05.02.13)
Discussion in 'Project Logs' started by hangar_15, 15 Mar 2012.
  1. hangar_15
    hangar_15 New Member
    3 Mar 2012
    Hello!
    I present to you the project is the construction of cyberspace.
    Cyberspace - a variety of electronic items that surrounds a person at work or at rest on the computer.
    Mount monitors
    removed from the frame of the monitor
    assembly of aluminum parts
    mount plexiglas
    I apologize for any grammatical errors
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    This thread needs subscribers. Count me in for the ride.
  3. hangar_15
    3 Mar 2012
    Nutman, thank you for your attention
    Area under the monitor - micro Eyefinity, version 1
    test
    version 2, beginning
    corners for the individual modules
    the monitor is gaming keyboard
    mounting weather station
    problem - the coating under the influence of temperature
    design option, version 2
  4. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    wow this looks interesting :D! Does it feel better with the new frames ?
  5. dream1
    dream1 New Member
    26 Feb 2011
    Very interesting! Keep an eye on it :)
  6. dirky90
    dirky90 Member
    19 Mar 2012
    how much information does one need at a time?? looks great tho.
  7. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
  8. hangar_15
    3 Mar 2012
    KoSoVaR^ after installing the plexiglass - slightly increased the contrast
    dream1 thank you
    dirky90 access to information is very useful. Unfortunately - TV - do not use. Netbook - inconvenient to use the keyboard.
    There was 2 version
    riekmaharg2 an interesting cable, thanks
    for games in Battlefield 3 and other shooters are used - X7-G100, A4-Tech XL-760H, Cyber Snipa
  9. hangar_15
    3 Mar 2012
    Start button, the computer is usually invisible to the system unit.
    The company produces Lamptron backlit buttons.
    You can make a button-based LCD, using a small frame and buttons.
    Photo frame is fixed on the buttons and when you click on the picture frame in the closed contact button.
  10. hangar_15
    3 Mar 2012
    Platform of TX2 and the control center
    Platform TX2 - symbol of the electronic system, the main place where the computer.
    The platform is based on a number of ideas.
    The first idea - "no compromise" with or without trade-offs.
    Of course expect to see NVIDIA GTX 690 and LGA2011 unfortunately it is not necessary, because - all done on personal money.
    However, some technical aspects to be implemented without compromise, and the first of them - a control center based LCD technology.
    The keyboard is made here on a membrane
    the creation of membrane keys
    Homemade membrane buttons are tested, working
    LSD installed frame
    installed homemade buttons on LSD will run two computer controlled lights and motors to install into a platform
  11. hangar_15
    3 Mar 2012
    A small entry
    The evolution of the design of computer cases is not as noticeable as graphics cards and processors.
    The lower the location of the power supply components kabelmenedzhmenta, 140-mm fans are relatively recent.
    At the beginning of the advanced solutions are applied in the cases a top segment, and then introduced into routine.
    Although the history of the buildings were small and revolutionary leaps.
    On the first of these, then, it is also a second idea of the platform TX2.
    Many of the computer is a square box in which you want to install computer hardware.
    And who said that the computer case has to be a rectangular box that is a ridiculous stereotype or dogma.
    What if we give up everything and to think more freely, the body which is established on the basis of knowledge of design, arhitektery.
    Thermaltake has a case Level 9, completely abandoning the square box.
    Lian-Li PC-888
    The layout of the platform TX2, tentatively will look like a house over a waterfall, created by architect Frank Lloyd Wright.
    The general idea - "TRON designs CORIAN ®" at Milan design week 2011.
  12. hangar_15
    3 Mar 2012
    Need help - how can you get a black nickel.
    Example - Power Supply Zalman.
    Appropriate paint color was not found :(
    Painting lacquer is not effective.
  13. KoSoVaR^
    19 Dec 2010
    you can do it by someone who nickelplates :)
  14. Nutman
    21 Oct 2008
    You CAN buy chrome spray paint, probably also dark chrome - but I seriously doubt that you'll be able to polish it up to the finish of REAL dark nickel plating.
    So, like Kosovar said: get someone to nickel-plate it for you.
  15. hangar_15
    3 Mar 2012
    KoSoVaR^, Nutman thank you
  16. hangar_15
    3 Mar 2012
    The base of the computer
    Dimensions - 0.4 x1 meter, height - 1 m.
  17. mindfulone
    mindfulone New Member
    6 Jul 2012
    Very compelling...sub'd :thumb:
  18. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    No such thing as too much!
  19. hangar_15
    3 Mar 2012
    Test paint
    the lower part - lacquer
    Copper
    Black metallic
    Chrome, silver
    Blue metallic
  20. hangar_15
    3 Mar 2012
    Year 2011: Experience creating overlays on MB
    Lamborghini style
    More bad painting MB.
    Overlay failed.
    Year 2012: new attempt
    Starting point - purchase Lamptron Advanced Slot Protect
    and the idea of platforms - modding hardware.
