Scratch Build – Complete Cygnus X1.
Discussion in 'Project Logs' started by Attila, 18 Sep 2008.
  1. Colossous
    Colossous Minimodder
    28 May 2007
    Great vision and execution :jawdrop:
  2. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    I vote for skipping an actual latching mechanism in favor of a few magnets embedded into the areas where the side and front panels (will) meet.
    - Diosjenin -
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    +1. Magnets would be uncluttered and firm.
    Just think carefully about positioning re. nearby hard drives.
  4. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    You could use very strong Neodymium magnets if you wanted although you would never get it open without a crowbar. HDDs are not affected by magnets much, they are shielded and have powerful magnets in them anyway. The only danger is a changing magnetic field, so don't move a strong magnet quickly by a HDD.
    pimonserry likes this.
  5. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    Which ever way is used to secure them its gonna look awesome.
  6. jhanlon303
    7 Sep 2006
    The pics with the doors open and the Alu chassis look positively Bang and Olufsen like Beolab. That's a good thing. High end audio as art - high end computer as art. Good comparison I think. Skill, workmanship, design, all spot on.
    Mod on. :rock:
    john
  7. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    WOW looking great!
  8. Attila
    Attila still thinking....
    22 Feb 2008
    Thank you. :)
    Thanks Colossous. :thumb:
    Thanks, see below for reply.
    Thanks, I've been a big fan of B&O stuff since the 70's. :D
    Thanks MM. :thumb::)
    The magnets are a nice, simple idea, and under different circumstances would be
    ideal. But there's a problem in this case.
    A few posts ago I remember saying (upon completing the first hinge and mounting
    the right side panel) that "there is no flex in the back plate". And this is true, the frame that supports the MB and drive plates gives plenty of strength to the back
    plate ON THIS SIDE. But this assembly is off center, and while it gives plenty of
    support to the right hand side of the back plate, there is little support for the other
    side. So when the left hand side panel is perpendicular to the back plate, flex is
    apparent. It's very small to be sure, but I don't have to measure it, I can see it. To
    remedy this, support needs to be provided at the front to take the load off the back
    plate when the case is closed up ( which is almost all the time).
    So this is the idea.
    The completed part.
    There will be two small "L" brackets fitted inside the panels to rest on the two
    platforms when they are closed. A single screw will secure each side.
    This bracket is mounted using existing hardware (no new holes), so the procedure
    is reversible. Once it's cleaned up and anodised it'll look like it's always been there. :D
    M7ck likes this.
  9. stonedsurd
    11 Mar 2009
    Good lord!
    This never gets old.
    :jawdrop:
    Jaws will be lying useless on the floor before this is over!
  10. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    Sir, we is like twinz 'n' that. lol
  11. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    :jawdrop: Just brilliant :jawdrop:
    One of the most stunning builds I have ever seen.
  12. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    MOTY material.
  13. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    fixed that for you.
  14. slipperyskip
    slipperyskip Member
    26 Oct 2003
    The miter in photo #6 is sexy. Pure Pr0n.
    Great job m8!
  15. Javerh
    5 Sep 2006
    +1
  16. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Damn that looks good. So, because you are securing the front of the door, it doesn't look like you intend on accessing the interior very often. Would be nice to have some kind of convenient spring-loaded catch there instead of a screw and cap nut so you can open the door without removing the front bezel. If anything to make better use of those gorgeous hinges you worked so hard on lol.
    Still, flawless work any way you look at it. :)
  17. thydzik
    thydzik What's a Dremel?
    19 May 2004
    one of the nicest mods I have seen.
    pity the aluminium work is all going to be covered.
    but judging from the sides, an all jarrah covering will look swell.
  18. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    What he said.:clap::rock::clap::rock:
  19. Attila
    22 Feb 2008
    Haha, Thanks. :lol::)
    Thank you. :)
    Thanks guys. :thumb::)
    Haha, thanks. :thumb: :lol:
    Thanks. :thumb: Yes, I was careful to make this reversible and of course your right,
    this solution is very ungainly and not very pretty. The top and front are to be hinged
    so opening the sides meant lifting the top and undoing the screw, about a 30 to 40
    second operation, way too long when a magnetic catch would mean opening a side
    could be done in a heartbeat. All I really need here is support, so see below. :thumb:
    Oh, and the only reason for hinging the top and front is to completely uncover the
    chassis when showing it off.
    Thank you. :) There will be acres of alu on the outside. ;)
    Thanks. :)
    The idea for fixing the panels never hit a home run, although I do like the bracket that
    supports the side panels. Support is all that is really needed here, and as Diosjenin
    and others have suggested, a magnetic catch is all that is required to hold the panels
    shut. It's a good idea just to be able to pop a panel and show someone the insides
    very quickly without any hassle.
    So to that end, both the "L" brackets and the support were modified to provide only
    support and basically get out of the way.
  20. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Whaaaaaaaaaaat?
    :eyebrow::eyebrow::eyebrow:
    It's not nice to tease us like that:nono:
