Case Mod - In Progress [Cyprus 29] CM Stacker : Update 18: Custom Fan Enclosures
Discussion in 'Project Logs' started by OrangeClockwerk, 3 Mar 2014.
  1. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Thanks hukkel! The router has been clutch for sure!.. lol @ Dr. Clock haha :lol:
  2. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    I think the whole community of modders is made up of magpies. Make something shiny and we all fall in love.
    Great work though Doc. Clock.
  3. OrangeClockwerk
    28 Jul 2013
    Haha thanks man, that is true =D ohhh shineyyyy haha
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    the Copper compression fitting turned out great Jim!
  5. OrangeClockwerk
    28 Jul 2013
    Thank you Bill!! I should have a tasty update either later this evening or tomorrow:thumb:
  6. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I was initially thinking the colours were not going to work, but I actually love it. Awesome work so far.
  7. OrangeClockwerk
    28 Jul 2013
    Thanks man! The scheme will show really well once I get a few of the key components in. Hope to have some of that next update.:D
  8. OrangeClockwerk
    28 Jul 2013
    Update 5: May 5th : Gusset, Shroud, and Sponsors!
    Hey everyone! Got another update for ya! I finished up the brackets I started at the end of last update and made the case sturdier with a gusset and a shroud through the bottom case. I am very pleased with the build so far! I also am stoked to announce that Primochill and Mod/smart are officially going to sponsor the build! I hope to have some of that in the next update! Also Cooler Master is going to sponsor the build with the new VSM750w semi-modular power supply! I plan to sleeve it up with Mod/Smarts new MaxCord paracord, and I will be painting the connectors copper! Thanks to these sponsors for helping make this case mod awesome!
    Now that I let you in on the great news, lets get into the update!
    First off Ill show you the brackets I fiber glassed to fill all the holes. They almost look like they came stock this way =D
    I decided to use rivet nuts instead of rivets so I can screw the case back together with bolts now.
    Now I had a nice neat bottom box ready.
    Next I made a gusset for strength using acrylic and aluminum cube standoff/nuts. My machinist is sending me the jig to make these and I should have them available for purchase soon after an overwhelming demand for them! Please visit my Facebook Page and leave a message for details. Ill leave a link at the end of the update!
    Just that little gusset alone made the case really rigid! Next up was the shroud which will have a small window to show the side of the power supply, and also will have my solid states that I use mounted on it.
    First I cut the shroud to size and marked lines to make my bends.
    After the first bends I sized it up to mark the excess to be cut off with the router.
    I had to make a notch to clear the lip on the right side. It ended up fitting really nice, then it was time to bolt it down.
    I marked off the cube mounts and got them all on.
    Once they were on I got it into place. marked them off on the case and then bolted it in.
    It fit like a glove and came out cleaner than I expected. =D
    While I had it tore down I added some MNPCtech.com U-Channel to the bottom panel on the top case that I cut out. It is without a doubt the best U-channel I have used. I left some slack because I will be coating it in white PlastiDip and the last time I did that it shrunk the U-channel a bit.
    Last I stacked up the case and took some photos of where I am sitting at =D
    Well that is all I have for now! Thanks again so much for checking out the build progress! Remember to check my Facebook modding page Clockwerk Case Mods for daily updates and to inquire about the aluminum cubes I will be offering very soon! Take care guys until next time!
  9. mnpctech
    21 Apr 2003
    can't wait for next update Jim! :rock:
  10. AlderonnX
    AlderonnX Minimodder
    10 May 2012
    Holy tower!
  11. OrangeClockwerk
    28 Jul 2013
    Thanks Bill! Keeping it rollin, next update should be even better, getting very close to adding hardware, some should even be arriving very soon =D
    haha its not quite the size of a double 915 stacker but its close =D
  12. OrangeClockwerk
    28 Jul 2013
    Update 6: May 27th : Parts came in! LED trim!
    Hey everyone!! Sorry for the delay in updates on the forums! I had an update prepared for last week and ended up moving my workshop from the pool house area to the garage for the summer and I collected some tools and had a huge organization break. So now I am back at it and it is smooth operator! Aluminum cubes are still available at Clockwerk Case Mods, just send me a PM for information! Alright now on with the updates! Lots of goodies came in and I started some of the cool details that will be in this mod!
    First thing is first, huge thanks to my awesome sponsors! You guys are really making this build extra special to me!
    Alright now I want to show you the goodies that came in! First up my power supply from Cooler Master! The newly released semi-modular VSM750w Gold Rated Power supply. I wrote up a little review, check it out >here< Next update I will have it all sleeved up with the Mod/Smart MaxCord I am about to show you!
    Alright now on to my Primochill & Mod/Smart parts!
    Bright white MaxCord paracord!
    Kobra sleeve for the sata signal cables.
    Connectors for making custom cables.
    Heatshrink to match.
    LED boards for the numerous single wired LEDs I have going into this build.
    Many bulkheads! Ill be custom painting them copper =D
    More revolvers than the wild west!!
    All the fittings I will be using.
    Can't connect the revolvers without PETG! Originally I was going to use copper tube and I was only using PETG behind the scenes to connect the bulkheads but I have a little surprise for my tubing later on!
    Can't forget the awesome selection of Primochill Intesifier Sicle Colors! That's all I can say about them though!
    Alright that's all the parts for now! On to the labor =D First is the LED trim, I use 1/4" acrylic stock and painted the face copper and drilled the ends for 3mm LEDs. Last night I ended up masking them off and painting the top for a more fuller look and the light will show out the bottoms.
    Once they were drilled and cut, they got hit with paint.
    Then I glued them to the side panel with my acrylic cement.
    It looked great but you could see some air pocket of glue because the stock wasn't perfectly flat. So I decided to tape off the panel and repaint the face and paint the top side as well, then clear coat them.
    I am glad I did that it made the copper effect more bold.
    I also glued my IO panel together. once I have my GPUs I will cut the holes for them.
    I also made a front bezel, I am going to redo it a little smaller to make it sit flush in the gap between the 2 original bezels but I can show you how I made it. At this point I decided I am going to use the copper paint instead of actual copper panels as I would prefer everything be the same color rather than real copper and not match exactly.
    Here I started with the acrylic trim.
    Then I cut some copper I had and painted it copper...copper on copper lol
    Once that was all set, I dropped it in to make a nice framed copper panel. I am going to try to trim a little off to make it fit, if that doesn't work I will just remake one, it was easy to do.
    The last thing I want to show you really quick is the interior mid plate bulkhead placement, I was going to drill and mount them but I want to wait until I have the corresponding piece of hardware to line up the fittings as close to perfect as possible. I think its going to look pretty amazing, you can get the idea if you use a little imagination =D
    Well guys I tried to load this update with photos for you since I had a delay between posts, I hope you enjoyed the update! Should have another juicy update for you in a little over a week. Oh yeah dont forget to check out my page Clockwerk Case Mods to get daily photos of whats going on in the workshop! Thanks again for checking out the build, take care =D
  13. OrangeClockwerk
    28 Jul 2013
    Update 7: June 9th : Started Custom waterfall reservoirs!
    Hey guys! I managed to start my custom reservoirs going. Im starting trim on the top one and I think I am going to redo the bottom one as one of the seams did not glue solid and I am having some leaks.
    I have also been busy with the CNC, its almost finished now, just need the spindle and some odds and ends. Once its done I can put my money towards buying the rest of the components for this build.
    Anyway on to the update! Hope you guys enjoy it!
    First thing is that I greatly appreciate the help from my sponsors, they are the foundation of this project!
    Here we go! I got my motherboard tray locked in place now with some aluminum cubes.
    I also went through and started removing the rivets and replacing them with rivet nuts so the case will no be assembled with screws rather than rivets. It makes things much cleaner and easier to break down and assemble.
    Next up I modded the bottom case bezel to hold two bulkheads and a little window to the bottom res. Two tubes will go from the top res and bring water down to the bottom res.
    I used the step drill to cut the holes out.
    Then cleaned them up with the dremel and put in the bulkheads.
    Next I cut out a window, I am not sure what trim to go with yet, white or copper. I might actually make acrylic trim for a more professional look.
    Now Ill show you the top reservoir. I am leaving the bottom res out because I am most likely going to remake it. Its only about 20$ in acrylic per reservoir without the trim.
    So I got the acrylic and some more syringes and a new needle from McMaster.
    I took the acrylic and cut it down to the correct sizes and made rabbit joints on the ends to make them more leak resistant when I glue them.
    I cut grooves in the mid plate that the water will flow over to hopefully keep the water a little more even.
    After all the panels were cut and rabbited I got to work getting the fittings in place.
    After drilling it was time to tap the front fitting holes. A good trick is to run the tap through a block of wood then into the acrylic. It keeps the tap straight and prevents cracking of the acrylic.
    Once the front were on I did the back return and top fill fitting.
    Quick set in place to get an idea of it, and then lay everything out to glue.
    This res glued together rather well.
    Final res without the trim.
    Filled it with some liquid and let it sit over night. It passed the test.
    Even if it leaked a little the trim will block all the seams with another layer of reinforcement. Here is the first trim panel I set up. I am bringing it up and around the fittings on all panels of both reservoirs. The trim will also be masked off and painted copper once glued on for a white-copper-white-copper contrast.
    Here is the trim in its glory. I am going to glue it square to the bottom right and flush cut the overhang. Then get it done.
    Well thats what I have for now. Hope you enjoyed it! Always love some feedback! I plan to have both reservoirs trimmed, mounted and connected for the next update. There are only a few things left that I can do before installing hardware, its finally getting to that point!! The CNC was eating my funds but after this friday I will be able to spend money on components. I already have my hardware decided and water loop as well. If you want to stay up to date on my progress daily check out my modding page Clockwerk Case Mods. Until next time modders!!
  14. montymole
    montymole Rigid Tubist
    24 May 2010
    love it top notch as ever
  15. NightRider
    NightRider What's a Dremel?
    23 May 2014
    Amazing work!
    And that res! Holly... Amazing, man, really!
  16. -MisterX-
    -MisterX- Minimodder
    22 Apr 2014
    Oh no! You took my amazingly original idea to do a copper/white build, LOL:D I'm still going to do mine though:p
    Amazing work, love it! Following this for sure.
  17. OrangeClockwerk
    28 Jul 2013
    Thanks Fred!!
    Thanks!
    Thanks man! Cant wait to see what someone else does with this theme =D I have never seen it done before thats why I ran with it.
  18. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Thou shalt be named custom rezman from now on.
  19. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Mr Acrylic at it again, very nice Jim :)
    oh and is it me or....
  20. OrangeClockwerk
    28 Jul 2013
    Hahaha Rezman!
