Scratch Build – In Progress "D.A.S." by Paladin
Discussion in 'Project Logs' started by Paladin | Patrick, 5 Jun 2016.
  1. kim
    kim hardware addict
    10 Jan 2016
    OMG...this can survive after a nuclear war...genuine steampunk computer!!! amazing, and your skills are just limitless...a real pleasure to see you working sir...
  2. Paladin | Patrick
    Paladin | Patrick LiveModder
    6 Jul 2010
    Thank you all
    Today I built from a piece of scrap from the DAS holders for the pump.
    I also still different variants how I could connect the pump.
    variant 1
    Variant 2
    variant 3
    variant 4
    variant 5
    Which is your favorite?
    So, that's again.
  3. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    variant 3 or 5 are my favorites
  4. Cheapskate
    13 May 2007
    3 Works. :D
    Since it will be soldered, you could employ some bent pipe for the tank radius.
  5. Paladin | Patrick
    6 Jul 2010
    So, here I have times the result of the vote.
    An update is then the dates'm just with what others busy.
    We-Mod-It
    1. III
    2. -
    3. IIII
    4. I
    5. -
    Hardwareluxx:
    1. IIII
    2. III
    3. II
    4. III
    5. -
    Bit-Tech:
    1. -
    2. -
    3. II
    4. -
    5. I
    Facebook:
    1. I
    2. -
    3. IIIII
    4. -
    5. -
  6. Dr. Coin
    13 Sep 2013
    Pretty poor voter turn out for Bit-Tech. Looks like option three was the favourite. Time for you to do option 6. :D
  7. Paladin | Patrick
    6 Jul 2010
    Yes, I have taken the sixth variant. Later more. :D
  8. ToddK
    ToddK What's a Dremel?
    3 May 2014
    Fascinating. Love it.
  9. Paladin | Patrick
    6 Jul 2010
    So, here in Worklog was indeed now ne now pause, but that does not mean anything has gone.
    In the contrary, there was so much to do that I had no time for the Worklog [​IMG]
    At first it was only once more with the pump mount.
    I enkoppelt the pump with rubber because the case is a wonderful orchestra.
    Inside I made a rubber between mother and housing.
    So now we come to the modified version. 3
    First off, I have instead used straight tubes bent.
    It sh from then. Unfortunately, I must note that the pipes the sound of the pump genuso transmitted as if the pump bolted directly to the chassis.
    Therefore, I have since then also decouples the pump with hoses.
    After testing everything I could soldering again
    The pump should then be the so disguised it looks like such an old engine.
    The tube that I bent down for the housing was still too large a radius, so I built a Biegevorrichtugn.
    As the radius had finally fit I could attach the screw again.
    Attached is the pipe nit hydraulic pipe clamps.
    Sometime is me then even remembered that I have no Fillports.
    Therefore I have made at the summit itself which.
    So drilled hole, sanded ...
    ... And a reducer soldered.
    But to me a good idea then came. These are automatic air vent.
    These are available only in 3/8 inch.
    Therefore, reducing sleeves had to be soldered off and normal sleeves again.
    the vent I have provided with rubber.
    When flowmeter me was to install a water meter the idea.
    This one I bought with shipping costs for about € 8.50 on eBay. [​IMG] Normal price would be somewhere at 35 €
    The day after the delivery but I then found this one in a Schrottkontainer, and is much better.
    Unfortunately, the flow direction is backwards. So I had to turn the measuring capsule. But had this nose soft here.
    Again, coming back the clamps for use. Since the housing but some I had to bend the pipe clamps something.
    To fit the water meter I had two each piece 45 degree arcs installing the water meter a little further takes away from the chassis.
    [​IMG] Al
    After the sheets were cooled again I could mount the water meters and drill the holes for the passages in the housing.
    After that I was able to adjust and solder the top.
    From customizing the second part here, I have no pictures.
    The piping is now outside completely finished.
    At long last I have made a tightness test today.
    A leaky soldering I've found that is nachgelötet after draining.
    Moreover, I have tested the pump, unfortunately with negative results.
    You is not heard because it is well isolated, but unfortunately it creates not even with 24v water obwoh to pump up a head of 3.6m is specified [​IMG]
    Since I will now, willy-nilly must zurückgreiffen on a circulation pump.
    So, what with 49 pictures again.
  10. Paladin | Patrick
    6 Jul 2010
  11. Cheapskate
    13 May 2007
    This thing is huge. It's not surprising that the pump is having trouble.
  12. Dr. Coin
    13 Sep 2013
    Looking great. Loving the industrial look. Too bad about the pump. For your beast of a case you might want to look outside current water cooling supplies and go old school and look a aquarium/pond pumps.
    Tip: When reviewing pump specification keep in mind that most manufacturers list maximum head and maximum flow rate, but these two values are at opposite ends of the pump operating curve. That is to say, you have max head when there is minimum flow and vice versa, maximum flow when there is minimum head.
  13. Paladin | Patrick
    6 Jul 2010
    The last update I have already said that the pump is too weak.
    Therefore I phoned times with Aquatuning, and supposing it with PWM pump is now and problems.
    Therefore, I can again send me 2 pieces without PWM.
    Thank you again here at Aquatuning
    So, at first dismantled everything and razed a huge mess [​IMG]
    Here the small package that I still get.
    The pump mounts are designed that the round to face looking at the pump is mounted. I wanted rum it differently, so I had to rebuild the brackets.
    The pumps are of course remounted acoustically decoupled.
    The central holes of the single pump. The nether 8 are required for the two new.
    Here the new tubing is now already mounted. The Smartcoils I also painted.
    I have also installed into the riser pipe under the water meter, a non-return valve.
    Then came the refilling.
    But this time I make an overpressure filling.
    But I had to install a compressed air connection in a canister.
    Then came a pressure reducer.
    The canister must be allocated to fill. The air then presses the water out of the canister.
    Unfortunately, here a sheet leak I have soldered the pump tag.
    Here is a video of the fill.
    [​IMG] video
    Today we went a bit further with the electrics.
    For that I had to first drill a passage inside me.
    In the hole came a grommet
    Outside still Strip and tin the ends. (Hab no picture from tinned wire)
    Between switch and socket I have made a pipe. Since the cable coming through. The pipe will be painted.
    So, that's it for today again.
  14. ToddK
    3 May 2014
    This is mad scientist at it's best. Well done!
  15. Dr. Coin
    13 Sep 2013
    Even your loop filling technique is over the top. But it look effective, I might have to adapt it for myself.
  16. Paladin | Patrick
    6 Jul 2010
    Thank you. I am glad that you like it
    Today we continued with the electrics.
    First, I made the connection cable from an old power cord.
    The brown I pinched off, which is no longer needed.
    So then looking out the finished cable.
    Fast thumb thick [​IMG]
    Here the can for the wall.
    It continued with the knife switches. At first I did it here assemble, but then told me not too.
    I then made the switch between display and surge tanks.
    Each switch hommt still a LED display. Since there are 220v Gilmm lamp inside. This also led to be rebuilt.
    For that I had to drill holes, and a recess a small nose is down there tuned here.
    This here are buttons light with control.
    The I mounted right next to the ads.
    For the fan coming up in the cover, I also installed a switch.
    Centrally above the adverts came even an LED indicator light for the main power connector. Den of the Power Switch to on is the key lights.
    The wiring inside will still be fun. Moreover, I have to think about how I will fix the so they do not hang out the cables in the area.
  17. Hunterbait
    Hunterbait That's how you change it!
    18 Jun 2016
    This build is the most overkill I think I've ever seen and I love it!
    For your cables inside, maybe some conduit and brackets to hold it along the sides.
    Keep up the excellent work mate!
  18. Cheapskate
    13 May 2007
    "So this is it for me? Tell my wife I lo-BLARRRG!"
  19. Paladin | Patrick
    6 Jul 2010
    Yesterday we went to the wiring of the main switch on.
    The ground was also extra again leftmost to the screw.
    This wire was already tuned original and is used to ground since the plate with the contacts made of plastic.
    Then the guard came on it again.
    Today the pump got their covers. Since fit coincidentally the lids of cans.
    The interior I just get milled Hand-held with the cutter.
    Fits perfectly.
    As I cover from a ceiling lamp, the hoods used under normal cables are clamped.
    But since I only needed the ground. Therefore I made with a cutting aid.
    When both parts were cut, I have this still being ground.
    For the cooling ribs I used Plexiglas. test First of 4 pieces for.
    Then the rest.
    Yes, looks ever not look bad.
    Prior to topcoat I first thick filler draufgemacht the all the joints are closed. Supposed to look like an injection molded part.
    Then I painted the covers Black.
    Pumps without covers ...
    [​IMG] ..
    ... And with covers
    Then we went again today with the electrics.
    Since the bakelite cable clamps and the cable came today.
    The strands are unfortunately stained, so I just tried what it is like when they are painted.
    Keeps fairly well when applying the paint very thin.
    Here you can see that it is an old cable. This is quite podgy, I think the strands are twisted.
    So, that's it for today then again.
  20. Paladin | Patrick
    6 Jul 2010
    Fits perfectly.
    Then the rest.
    [​IMG] ..
    ... And with covers
