D-link router...
Discussion in 'Tech Support' started by c.u.later, 23 May 2008.
  1. c.u.later
    c.u.later New Member
    16 Apr 2005
    hey guys, bit of a weird one this, as far as I can see everything's set up right for a network between computers, but I can only see the computers connected by wires to the router when I look on one with wires and vice versa, as if the wireless and wired network connections are seperate? maybe a feature, but I really hope not as I'd like to transfer some stuff over, any ideas guys?
    thanks,
    c.u.later
  2. Denis_iii
    Denis_iii New Member
    1 Jan 2007
    can you ping the PC's connected by wireless from a wired PC? try by IP address and Netbios name, are they on the same domain\workgroup?
  3. superseagull
    superseagull If it aint broke, fix it ;-)
    28 May 2008
    are all your machines running the same operating system and connected to the same router (make sure the wireless machines are not on the neighbours wi-fi!). if so as denis said try pinging the ip addresses to see if they are connected on the network if so u can likely share data with a little configuration.
    to ping open the command prompt and type (eg) ping 192.168.1.5
    best of luck
