Storage D-Link Share Centre
Discussion in 'Hardware' started by Zinfandel, 24 Aug 2011.
  1. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    So just seen This in an email from Scan...
    Just looking for some advice really, I think this would be perfect for me.
    I need to hook up my main PC and media PC to some kind of storage effort. I could put 2 x 2tb in there and that would be more than enough storage for me.
    I want to keep all my films and music on there so I can play from either my PC or my media PC.
    Would that do the job?
    EDIT: Oh, it's only got one ethernet point... Seem kind of pointless.
    EDIT EDIT.
    Would I be able to connect it to a router connected to the PC and media centre and access it that way?
  2. ryan498
    ryan498 What's a Dremel?
    6 Aug 2011
    It's a network attached storage drive so it is designed to be plugged into a router, the router will then assign it an IP Adress which you can then access the settings for the device though an internet browser. It would appear as a network drive in your my computer, I also had a quick look and says then it has a USB connection too. So i would have thought you would be able to directly hook it up to your computer via USB too :)
  3. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Wow, this is awesome.
    I might get one of these and a pair of 3Tb drives!
    Cheers Zin.
    TSB
