Windows D:\My Music is not accesible
Discussion in 'Software' started by Spiral Architect, 28 Nov 2003.
  1. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    ...Thats the error message i'm getting when i double click on the folder. It only started doing this after i reinstalled windows because i upgraded my motherboard.
    Under that it says 'Access Denied'. I'm logged in as administrator so i have the authority to see all the files.
    Anyone got any ideas?
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    goto the folder's properties, and make sure that Administrators have the right to view, and under advanced make sure that your user, or administrators is the owner
  3. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    right click, properties, security (its a tab at the top), advanced, Owner, tick "replace owner on subcontainers and objects" and then double click on the user you wan to own the folder.
  4. Spiral Architect
    4 Sep 2003
    Nedsbed: I think that option is only available on Win XP Pro.
    I still can't get into it. Its very odd that the one folder i actully give a damn about is the one that got messed up :wallbash:
  5. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
  6. white modder
    white modder What's a Dremel?
    19 Sep 2003
    checked and saw this is right
  7. Spiral Architect
    4 Sep 2003
    Thanks you guys. I got back all my music files.
    Thanks again, i really do appreciate it.
