Scratch Build – In Progress D33P THOUGHT, ..COMPLETE..FINAL PICS+VID
Discussion in 'Project Logs' started by Asouter, 21 Jan 2012.
Hoopy or Tart3 handbag
Poll closed 16 Apr 2012.
  1. Hoopy
    95.5%
  2. Tarts handbag
    4.5%
  1. Kiliv
    Kiliv New Member
    2 Sep 2011
    I think i have just fallen in love with this build and those rads! great work dude
  2. Asouter
    Asouter --------
    18 Jan 2012
    Sorry Jeff, There's no way I'd put them under the bed, well not without wearing boxing gloves to sleep in LOL.
    Cheers Wejjy, I can't wait to see it finished either, the sanding is getting mind numbing, but very nearly there with all the complex shapes. Update to follow.
    Nahhh I don't think you should regret it, You definitely earned some Kudos from all these guys following the thread, Looking forward to your build.
  3. Asouter
    Asouter --------
    18 Jan 2012
    Ohh very nearly forgot, for all you Radiator purves , Give Crappy some Kudes
    Thanks
  4. Asouter
    Asouter --------
    18 Jan 2012
    UPDATE 15/02/12
    Ok it's been a few days since an update and apologies for the late replies to posts. Not being rude just extremely busy. Work, Build, Living and Moving house yadda yadda yadda.......
    Ok I've been working on the rear towers and housing those Reservoirs, The shape differs from the front towers. This is to reduce the size of the case and also to allow the motherboard to fit. The shape will change again half way up but that's for a later update.
    Here's a few pics showing the shape and how the reservoirs fit into them
    Those frosted edges are working well, it's impossible to look at these things from just one angle those lines draw the eye around to the back and when you get there, you want to go back round to the front. Gets a bit dizzy after a few hours. :lol:
    Here's how the overall build is shaping up, The next task is to sort out the motherboard tray but for now enjoy the pics
    STAY HOOPY :cooldude:
    theoeyeo likes this.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
  6. The_Crapman
    5 Dec 2011
    And almost immediately another idea pops up while lookin at you pics. But don't worry, this shouldn't cost any money...
    With the frosted edges you're not gonna be able to see the gargle blaster logo very well, if at all, so you could make a strip clear where you want that on view.
    Or you could tell me to shut the hell up and slap me like I'm an hystericle woman.
  7. The_Crapman
    5 Dec 2011
    he he he....DP.....he he he
  8. Asouter
    Asouter --------
    18 Jan 2012
    Yeah I was thinking the same, the logo's do line up to the front of the case, I have polished inside the circles, but a strip might be the only solution. I will have to see how it "PANS" (pun intended) out.:D
  9. Sarakon
    Sarakon The German
    11 Feb 2011
    TY :D
    lol, I was gonna say that...
  10. Asouter
    Asouter --------
    18 Jan 2012
    It's still a good spot though, it was the first thing I thought when putting together the reservoirs
  11. Asouter
    Asouter --------
    18 Jan 2012
    UPDATE 18/02/12
    Ok time for an update,
    I'm moving house at the moment and D33P THOUGHT is going to have somewhere to live, it's not gonna survive on the floor. What I've done is I have an old marble block that I store general tat and stuff in and thought it a good idea to put a "mid" smoked top on it and use what's left of the smoked acrylic to make the M/Board tray + the top of the pc with.
    I've also acquired a rather nifty marvin sign that I can use in the base
    The complete base looks pretty good and will really show the build off quite nicely.
    With the acrylic left over i have made the M/board tray and the top for D33P THOUGHT.
    I have fitted the tray and still deciding if I'm going to cut out holes for the tubing or to use bulkhead fittings with quick release connectors, I'll get a better idea once the protective film is removed but for now I still need to drill and tap holes for the stand offs
    I have also trimmed the back layers for the reservoirs, this will allow the I/O shield to be fitted, the treaded rod will be trimmed and capped off with a nut to secure the bottom plates. Once I have cleared the I/O shield I will revert back to the original shape
    and for the last pics I have done a quick mock up to see just how big the build will be, I can see the light at the end of the tunnel with all that sanding and looking forward to getting stuck into the fun bits.
    Stay HOOPY:cooldude:
  12. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Love that table :)
    Man your mod is getting shape now, its getting better and better !
  13. Charmy
    Charmy New Member
    31 Jan 2012
    Looking goooood :rock: :clap: ;)
  14. peteski
    peteski long live the pc
    8 Jun 2011
    cant wait to see this finished mate it's gona look amazing :rock: :rock: :rock:
  15. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    The Don't Panic sign is a really nice touch :D this project is sho aweshome :thumb:
  16. Asouter
    Asouter --------
    18 Jan 2012
    Thanks Bladesingerz, I was wondering if you'd notice the m/board tray :thumb:
    Cheers babe ;)
    Thanks Peteski
    I can't wait to see it finished too, the case is just the start but I really need to nail that before the hardware install....it'll get there but in the mean time keep rockin :rock:
    Thanksh man, The Don't Panic sign very nearly got chopped for the bits I wanted inside the case, but glad I didn't
  17. wejjy
    wejjy Active Member
    9 Aug 2010
    That looks great mate, really starting to come together, I like the style!
  18. Sarakon
    Sarakon The German
    11 Feb 2011
    quick question? how did this pop into your mind??:jawdrop: looks super amazing...
  19. Asouter
    Asouter --------
    18 Jan 2012
    Thanks Wejjy,
    It's difficult to keep the style, with the theme it would be very easy for it to look like a cartoon.
    The reply might not be as quick, How do you try to explain how the idea for this "popped into my mind" all I can say is that there was a lot of time spent looking at other designs on here and trying to think of something original (not easy) Having said that it has given me alot of ideas for future projects, I mean the design of motherboards has changed dramatically over recent years (The ROG/ASUS boards are my fave's) and some of the styling fits very well to this type of build. I'd like to do a build that extends the cooling fins on the ASUS boards to the outside of the case.....I found on my Rampage 3 that the fins as beautiful as they are kinda got swallowed up by other hardware and the feature was lost. It very nearly broke my heart to take the chipset heatsink off to install the waterblock. I'm waffling now but I would say that alot of waterblocks are pretty flat, I'd like to see them with fins much like the heatsink on the asus board. :eyebrow:
    Oh thanks for the compliment btw :thumb:
  20. The_Crapman
    5 Dec 2011
    AAAAAARRRRRRGGGGGHHHHHH!!!!!!!!!!! :miffed::miffed::miffed:
    Jealous just doesn't cover it.:nono: everyone else may as well stop doing any big projects as MOTY is over already ;)
