D5 pump PWM- brain dead :duh:
Discussion in 'Watercooling' started by hairyknacker, 27 Aug 2015.
  1. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Howdy- having a very senior moment here
    Going back to water for a build and have a D5 pump with pwm 4 pin connector- if I connect to motherboard, will I be able to control the output? If so, any recommended software.
    Last time I was under water, I had a D5 pump connected to an Aquaero 5 via aquabus and my current fan controller- a Lamptron Touch- only has 3 pin connectors so don't think that would work- or would it?
    I know these are the most stupid questions ever asked but have just had a complete brain freeze:duh:
  2. David
    7 Apr 2009
    I doubt you'll be able to drive a D5 off a motherboard fan header.
  3. Big Elf
    23 Apr 2009
    If it's a PWM pump there should only be 2 wires into the 4 pin Fan header with another 2 wires for power ending in a 4 pin molex type/auxiliary connector to go to a PSU connector.
    If you have an Asus motherboard then Fan Xpert (part of the AI Suite) is pretty good for PWM control, otherwise Speedfan which can be a bit complicated to setup usually works.
  4. hairyknacker
    25 Jan 2012
    pump does have a molex for power- see- having a total nightmare of a day!
    mobo is a MSI gaming Z97 ACK thingy and not sure what that has software wise- I am aware of Speedfan so will see when I finish the build- be a week or so as waiting on fittings
  5. Big Elf
    23 Apr 2009
    If you do end up using Speedfan then Martin's guide here is very helpful in setting it up.
  6. hairyknacker
    25 Jan 2012
    Thanks for that Biggie!
    Much appreciated :thumb:
