Memory Daft question -DDR4 3600 running at 2133
Discussion in 'Hardware' started by iknowgungfu, 19 Jul 2020.
  1. iknowgungfu
    iknowgungfu Member
    28 Aug 2011
    Hi,
    Sure I am missing something but in my BIOS my RAM only shows it running at 2133.
    Both XMP profiles show 3600 but the speed doesn't change. On CPUID it lists it at 1600 (which I presume is 2133 in reality).
    What am I missing?
    I'm on a B550 MSI Tomahawk with latest flash etc.
    Thanks in advance - it's winding me up no end!
  2. iknowgungfu
    iknowgungfu Member
    28 Aug 2011
    Ignore me. It seems I am a tit. I was failing to save changes as I exit BIOS (was too busy tinkering with fan settings and forgot I had changed profiles.
    :wallbash:
    silk186 likes this.
  3. iknowgungfu
    iknowgungfu Member
    28 Aug 2011
    Although - now in CPU-Z the DRAM frequency is set at 1799 (assumed to be 3600) but under SPD it still says Max bandwidth is DDR4-2133(1066 MHz).
    Should I be concerned with this? BIOS seems correct.
  4. sandys
    sandys Well-Known Member
    26 Mar 2006
    SPD is the programmed defaults of the ram, not the speed it is running at, if you set ram too fast and have to do a bios reset or it fails training the SPD setting is what the RAM will default to so you can get running again.
    Bloody_Pete likes this.
  5. iknowgungfu
    iknowgungfu Member
    28 Aug 2011
    Cheers.is it normal to have an SPD lower than the actual RAM sticks I bought?
  6. sandys
    26 Mar 2006
    Yes, it will normally have a couple of speeds but speeds like 3600 are XMP/overclocks not official standards, not sure JEDEC goes any higher than 3200 (not researched it, so don't quote me :D)
    iknowgungfu and Bloody_Pete like this.
  7. iknowgungfu
    iknowgungfu Member
    28 Aug 2011
    Cheers. I'll stop worrying about it and go to bed now.
  8. wyx087
    15 Aug 2007
    Time to update your signature :)
    Tagging on to this thread. What's people's view on safe DDR4 RAM voltages? Most kits these days list 1.35v for their XMP profile, does it mean 1.4v is still considered safe if pushing the OC a bit beyond XMP speeds?
  9. sandys
    26 Mar 2006
    After 1.5v you maybe need to give consideration to cooling, in fact with my board I get instability without cooling here as my power ICs are next to DRAM so when pushing hard it all gets toasty but that is on TR with memory on both sides of board, unlikely to happen on normal Ryzen. My mem instability happens at quite low temp of ~60 something C, so I use a fan.
    1.4 is fine.
    wyx087 likes this.
  10. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    I tend to stick between 1.35 and 1.4 althought 1.37 seems to be the sweet spot for my TG B-die RAM.
    wyx087 likes this.
  11. wyx087
    15 Aug 2007
    Thank you both. I'll have 1.4v as my upper limit.
    I've managed to overclock two single stick pack A-Data 16GB 3000 CL16 sticks to 3400 MHz, same timing, dual channel, at 1.365v. They are B-die 2 rank and only costed me £104 for 32GB :D
