Modding Daisy chaining psu connectors?
Discussion in 'Modding' started by metarinka, 23 Feb 2004.
  1. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    hey yall, I'm fairly sure this should be okay just making sure as I'm more of a self taught electronics dude
    Would it be okay to run every drive and peripherial from the comp on 1 line thats just been Y splitted a bunch of times, the psu woudln't be under any more than its normally has nor would it be very close to its MAx W, I just was wondering if there's issues with line clairity, signal strength etc. what order I should daisy chain etc
    In case you wondered its an Antec true power 440W.
    and heres what would be chained
    3-4 HDd's, 1-2 optical drives, ~4 fans
    Didn't want to start smelling smoke if the line gets to hot or anything wondering if any of you guys had exp with this
  2. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    i had issues with my 300w when i did that
  3. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    No problems if you power supply is 450 Watt+, in this case more is better if you can afford it... :D
    Ran 6 SCSI hard disks on a single chain on a 550 Watt powersupply and had not problems...
    good luck :yawn:
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Just as long as you don't pull too much current through the wires you are okay.
  5. metarinka
    9 Feb 2003
    I'm gonna go ahead with it, my only worry was I was gonna pull too much from the wires or get a really "dirty" signal. I Was gonna desolder most of the other lines to save space in my case too. wish me luck!
  6. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    Good Luck.
  7. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    watch out... if you pull to much current, it could not work... or be like my ****ty ass psu and destroy
    your :
    mother board
    dvd rom
    cd-r rom
    hard drive 1
    hard drive 2 bootsector
    1 fan
    radeon 9600 pro
    and itself...
    so watch out. :D
  8. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    Personally I would be worried about drawing too much current for the wire and melting it. But that's just me personally.
  9. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    Well I had issues running 2 hdds and 2 cdroms off the one line, some of them would power done and any time i ran both cdroms the hdds crashed and gave me a bsod. I just unsoldered all the wires from the psu and ran one uber thick cable and split all the molexes off that never had a problem again.
  10. Bmw M3
    Bmw M3 What's a Dremel?
    24 Dec 2003
    dont use Y splitters it will look messy get 90 degree molex then there is only one wire but lots of connectors :D
  11. irsekz
    irsekz What's a Dremel?
    23 Feb 2004
    before you plug it in put a volt meter up to each moltex and make sure its all go
  12. TMM
    TMM Modder
    12 Jan 2004
    i have everthing in my case except my Aero7 and HDD on one chain. so i've got 2x cd/dvd, floppy, 3 case fans and controller, ccfls and a little LCD on one loop :p
    i have a 400watt psu, some cheapo brand so i wouldn't care if i damaged it
