Modding Damn... help?
Discussion in 'Modding' started by Shadowed_fury, 12 Feb 2004.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Ok.. i've got a motherboard that says it supports..
    400fsb celeron, 533fsb p4.
    i want to use this as a temp fix, cud i put a 800fsb p4 in it, and it work?
    it'll only be for like 4 weeks, i'll get a abit IC7 after... :D
    thanks
  2. ionpcs
    ionpcs Banned
    28 Jan 2004
    I don't think that P4 processors work like that. I know with AMDs it is possible to sometimes just run the processor at a lower fsb speed but i think p4 processors are different. Why would you want to do that in the first place? You could get a good quality p4 board for about 50 - 80 bucks on newegg anyway.
  3. Shadowed_fury
    21 Nov 2003
    i'm not rich. :hehe:
    i just need to know if this works, i'd have an offer lets say... :D
  4. Fubar
    Fubar What's a Dremel?
    7 Oct 2003
    it will work it will just run at 133fsb
  5. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Just make sure you don't put a Prescott in there. If it can't even support a 800mhz FSB P4, then it's quite likely that the VRMs can't handle all the power Prescott pulls.
  6. Shadowed_fury
    21 Nov 2003
    Just a regular 800fsb p4... wud this work? :worried:
  7. Megavolt
    Megavolt What's a Dremel?
    4 Apr 2003
    It should. I have a 533FSB P4 in a 400FSB board and all I lost was core speed.
  8. Shadowed_fury
    21 Nov 2003
    its looking good
    i'm pretty sure it'll work actually.. rubbish compatiblity otherwise :hehe:
