Modding Damn wires clean up...grumble..
Discussion in 'Modding' started by MiNiMaL_FuSS, 22 Mar 2004.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I decide to do sum major wire clearing now i have a lit window in my case.
    After like a couple of hours of putting cables everywhere and hideing them, i finally was done, only place u could c cables wa sup by the PSU and where they came out of the actual drives.
    Great, my window dosnt let u c up by the psu anyway...so perfect...fitted a nice nu fan aswell.
    DAMN - system exaughst blower isnt going....musta knocked the power wire out...What to do? Destroy hours of work and do it all over again to get the damn thing going...or just forget about it for now.
  2. instant rice
    instant rice What's a Dremel?
    20 Jan 2004
    Just try to follow the wires from the blower itself. Also, if you have a voltmeter, you can peel the sticker off the fan and probe the contacts to see if you're getting any juice. Check to make sure it's plugged in completely, too.
  3. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    I have run into the same problem with my wire tideing. After I did some managment none of my lights work (I figured out that it is a loose conection under the radiator near all my switches) if i push on the wires under the radiator they will turn back on, but they go off randomly. I have just decided to leave it for now as I am working on a new case anyways. but for you I would definatly try to fix the problem, as wire managment is futile if the wires dont lead to a working device ;) good luck with it and i would love to see a pic of it if possible.
    JEEVES
  4. MiNiMaL_FuSS
    24 Dec 2003
    Just added to project logs 'silver sheek', check her out
