Cooling Damn you waterchill
Discussion in 'Hardware' started by chiggyman, 6 Sep 2004.
  1. chiggyman
    chiggyman Banned
    18 May 2004
    Ok well i just got given an Asetek Waterchill for my bday (yes today wooo wish my happy birthday lol) Anyway, i have a socket A CPU, yes i want 64 bit, i also need lots of money. Well unfortuantely the Antarctica CPU block tha came with it, doesnt fit. Cus of those fat capactiors around the motherboard, now i thought about chopping the offending moounting holes off, but its VERY tough perspex. Does asetek send you one that fits free of charge, do they even make one? Or do i have to spend some money on some dangerden stuff tht might fit my motherboard. Also if it should drill a hole in the top of my case for a 120mm fan, how big should the actually hole be, cus i know its not 120mm. A little bit under i presume. (For mounting the radiator btw)
  2. Firehed
    15 Feb 2004
    I thought they usually also include a socket A top which has a smaller profile.... try calling them and ask.
  3. Risky
    Risky Modder
    10 Sep 2001
    The lity should fit Socket A its only socket T that has a different lid for antartica.
    Time for the :dremel: and chop off the offending bits. This is not unkown with theis block and socket A. If you want to be able to use it for an A64 later make sure you leave those mountings alone if possible.
    Oh and the kit should work well. I rate it :D
  4. chiggyman
    chiggyman Banned
    18 May 2004
    Nope theres definitely no other top in the box ive searched for aaaages lol, and if definitely doesnt fit, theres several capactirso it hits. I could just chop them off but this stuff looks like solid material and the whole idea of me gettings a kit was 2 literally just put it straight in, i just hope asetek have friendly teck support
  5. Risky
    Risky Modder
    10 Sep 2001
    Their own forums are at http://forum.vapochill.com/ and its pretty helpfull there.
    Now lookign into it there appears to be a socket A lid that migth be a little smaller, though again I should say that the originsal lid would work if the caps hadn't strayed into the reserved areas.
    If you want to mod the lid I think you can cut with a dremel or hacksaw. particlarly if its just the S478 fixings which you don't need.
  6. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Move the offending capacitors :dremel: That's what I'd do anyway...
  7. Risky
    Risky Modder
    10 Sep 2001
    What is it with Socket A boards they seem to push it to the limit to squeeze the largest components and close to the socket as they can :wallbash:
    I have to hack into the HSF with allof the (cheaper) SoA boards I've inflicked on my in-laws.
  8. chiggyman
    chiggyman Banned
    18 May 2004
    Problem solved :dremel: , hehehehehe, stupid asetek, like im gonna pay £20, for a socket A top, with my trusty dremel its free and i get satisfaction of cutting it up, ahhhh
  9. Risky
    Risky Modder
    10 Sep 2001
    pics?
  10. chiggyman
    chiggyman Banned
    18 May 2004
    I might post pics later, until now, im struggling to fit the radiator, more carnage needed, and sleeving the pwoer supply, time connsuing :wallbash: crap lol. The perspex they made it out is tough as hell, broke a industrial jigsaw blade. Its like metal. O well, dead metal, mwuhahahah
