Electronics Damp sensor
Discussion in 'Modding' started by RascalRusty, 20 Jul 2004.
  1. RascalRusty
    RascalRusty What's a Dremel?
    7 Jan 2003
    Hi all,
    bit a or silly question, and I am sorry it not to do with computing, but how can I make a small water detector, that could fit between the sealing joint of a bathroom waste drain. The reason I ask, is cause the joint is hidden under the floor boards, and so should the seal ever spring a leak, i dont want to wait 4 months to notice it when my ceiling is sagging due to it being soaking.
    Thanks guys, and sorry!!!
  2. tmod
    tmod What's a Dremel?
    9 Apr 2004
    This could be useful, maybe?
  3. Zwox
    Zwox What's a Dremel?
    8 Jul 2004
  4. Emon
    Emon What's a Dremel?
    14 Jun 2004
    This should do it. It normally turns on a bildge pump, but you could have it turn anything on, an alarm for example.
  5. Manitowic999
    Manitowic999 What's a Dremel?
    17 Mar 2004
    A simple float switch?
  6. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Make a PCB with two unconected tracks in a spiral with a few mm gap between them. If water falls on the board, a weak conection will be made and can be used to trigger a transistor by using the PCB in a standard potential divider arangement with another resistor. You could also just use two wires or bits of metal.
