Cooling Danger Den Maze 4 GPU block
Discussion in 'Hardware' started by uwannabigmak, 5 Mar 2006.
  1. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    Will the standard Maze 4 GPU block allow for a PCI card in the slot below, or will I need to get the low-profile version of the block? What kind of performance drops are there with the low-profile version?
  2. koola
    koola Minimodder
    11 Jul 2004
    Not sure on the low-profile performance, but the normal maze 4 will block the PCI slot below it.
  3. Nexxo
    23 Oct 2001
    You need the low-profile version. There should be no difference in pressure drop, as the main constriction is in the copper plate half of the block, not in the pathway from the barbs to the copper plate in the Delrin half.
  4. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    (/me pops open V1000)
    A PCI card won't fit one slot below the low-profile version either. There's plenty of clearance for a card two slots down, though.
  5. uwannabigmak
    30 Dec 2004
    so... what exactley is the point of the low profile version? shuttles maybe?
  6. Nexxo
    23 Oct 2001
    No, SLI setups.
  7. stev
    stev What's a Dremel?
    11 Aug 2005
    Corsair sells a low profile block that allows two PCI or other cards to fit next to each other; P/N CWC100-1003. At the CES they showed an SLi setup with two cards on a MOBO using these cold-blocks. The fitting size is 3/8"
    http://www.monarchcomputer.com/Merc...e=M&Product_Code=270897&Category_Code=CaseMod
    I can't remember, at this time, what review site had posted those photos. They were showing off the COOL and the newer unit of the Nautilus 500.
    Here is the gpu-block on a single graphics card:
    http://www.systemcooling.com/images/reviews/LiquidCooling/Corsair_Cool/Image19big.jpg
    http://www.systemcooling.com/images/reviews/LiquidCooling/Corsair_Cool/Image20big.jpg
    http://www.systemcooling.com/images/reviews/LiquidCooling/Corsair_Cool/Image24big.jpg
    This last shot shows how close another card could fit.
    http://www.systemcooling.com/images/reviews/LiquidCooling/Corsair_Cool/Image28big.jpg
  8. Darv
    Darv Bling!!
    12 Aug 2002
    Another option is to get an Alphacool / Aquacomputer etc block. They are all very low profile so should leave enough space.
