News Danger Den MAZE4 Power Water Cooling Kit at MODTHEBOX!
Discussion in 'Article Discussion' started by GreatOldOne, 28 Aug 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    MODTHEBOX! gets wet and wild with DD's power water cooling kit:
    "The highlight of the Danger Den Power Water Cooling Kit is the inclusion of the latest MAZE4 revision water block. The water block is comprised of two separate pieces; a laser cut Lucite top and copper bottom which are secured by six screws. Two chrome valves (inlet and outlet) exist on the top portion of the Lucite plate and are compatible with 1/2" ID tubing. The construction of the water block was completed using high precision CNC and laser production methods. The formations of the walls on the copper base enable the water block to efficiently distribute water above the core of the CPU and effectively cool at lower temperatures."
    Full review here
Tags: Add Tags
