Modding Dangerous UV cold cathode
Discussion in 'Modding' started by eegg, 21 Dec 2006.
  1. eegg
    eegg What's a Dremel?
    29 Aug 2006
    I read somewhere that uv light is dangerous and can cause cancer it it true?
    becasue i want to buy Uv cold cathode tubes
  2. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    its fine, UV covers a very broad spectrum of light frequencies (basicaly any light with a higher frequency than visible light), UV cold cathode lights (black lights for our friends in the US) generaly emit the lowest frequency light possible for them to be clasified as UV.
    UV can be dangerous but only when you get to the higher frequencies such as the UV light thats given off by the sun and tanning beds.
    don't worry, you'll be fine.
  3. joe-coleman
    joe-coleman What's a Dremel?
    29 Oct 2006
    thats if the inverter doesn't set on fire. of course.
  4. Ener
    Ener What's a Dremel?
    17 Oct 2005
    or explode :thumb:
  5. eegg
    29 Aug 2006
    thanks i'm going to buy :)
  6. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    i don't get the big beef with inverters exploding, mine have been fine for what seems like forever, though they are sharkoon ;) oh, and my inverter is out of the way of any of my components (velcroed low down to the outside of the drive bays) just to be on the safe side. Make sure you do too!
  7. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    didnt realise they where dangerous why is this? (inverters)
  8. g_gimbert
    g_gimbert Minimodder
    9 Jun 2002
    Mine have been fine too, and ive got those cheapo ebuyer ones (3 of them), had them about 3 years now at least.
  9. joe-coleman
    29 Oct 2006
    haha thats like saying, i dunno what it is about people saying these cheap hairdryers kill you in the bath.... although mine was expensive.... and i don't use it in the bath.... :D
    It's a quality issue. Cold cathodes are a "cheap" mod. but to make them cheap, they make really bad quality items. This can equal fire!
  10. Ener
    17 Oct 2005
    i think the ones were from a bad gen, as in they all were exploding in 04? (maybe 05) but as makers keep changing parts they become more stable... sometimes
  11. r4zor
    r4zor What's a Dremel?
    22 Dec 2006
    uv light is diferent of uv radiation.no problem with uv light
  12. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    If you can get ccancer from a burning/exploding inverter fear for your life if you can't then protect your comonents (and maybe you pets and children or spouse)
    Also UV lights and any light really actually produces UV radiation its a known fact the amount well Ill let you guess why you can sit next to lights all the time and not get cancer.
  13. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    the amoutn you would be exposed to would be minimal, Uv cold cathodes are fine, it's not like you work in a club that runs black lights 24/7
  14. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    The UV light is no problem but I'd suggest you put your inverter where it wont ruin anything if it explodes all of a sudden. The chances are very slim but just in case, it only takes a few seconds and can save you components
  15. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Even then it doesn't matter. The wavelengths of those UV lights are far too big.
    Light is radiation, therefore UV light is UV radiation. It's just not a problem until it's very short wave UV and in high exposures.
  16. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    Also the tubing containment filtrates the light to quite an extent.
