fantastic build! i agree with the guys above i think staying with clear water would be best, can't wait to see the both of them working!
Probably like small metal bearings rolling around the bottom...... It would probably mess up the pump if it got sucked up as well.
Thanks to all for interesting It could be a good idea... wich kind of minimal themperature alteration would be enough to see a chromatic difference?
There will be one pump for each reservoir. In a few time , I'll do another test with rad and WB. Thanks for the interesting link, you given me.
I really concorde to you. I belive you'll find, in my "Dark Blade" something familiar. NO, Absolutely quite... shhh!
The pumps I'll use for the 2 reservoirs are "NJ 1200". The noice that produce is really imperceptible. I do my all of my best... sometimes, if you like to see something cool, you should spend a little bit of your time waiting for the incoming updates. work in progress
That's an original idea... I concorde to you because the mercury would be for sure suck up by the pump.
What kind of color is that water going to be? just normal clear? green? blue? red? orange? yellow? .....
x2, I'm a newbie here too (look at my postcount lmao..) but I'd say keep the water clear.. as it will fit the colorsceme you (seem to be) are using. Very nice so far dude, keep it up and we awaiting the next update
another vote for clear. any color would just clash with the silver. i generally prefer clear water, although stopping corrosion would be difficult. poll, maybe... GREAT mod i wish i had such great skills/equipment.
as ive stated allready: clear, clear, clear as for merchur, the pump would just massarate it and there would just be loads of hard to remove little droplets, it would look dirty and isnt great for cooling performance.. Snood
