Scratch Build – In Progress Dark Blade by G69T
Discussion in 'Project Logs' started by G69T, 30 Nov 2004.
  1. G69T
    G69T CNC Modder
    6 Jun 2004
  2. Static Lullaby
    Static Lullaby New Member
    1 Feb 2006
    Absolutely beautiful work!
  3. phuzz
    phuzz This is a title
    28 May 2004
    :duh: oh, that's why there's no fan holes on the back, it's all water cooled, I see now.
  4. lepre
    lepre Member
    28 Aug 2003
    that's why there is all that stuff under the case :D :D
  5. praetor coda
    praetor coda New Member
    6 Aug 2005
    Hey G69T,
    Man, I am digging all that machining; drooling to be precise. I am following this build like a fanatic stalker...don't get crazy people, I mean the build not the builder. I am building a machine that is based on a VMC a design, much like the machine you are working on, only on a much smaller build, that is what you are milling your pieces on, (a VMC), correct? Now are the beveled edges being machined with a radius bit?
  6. G69T
    G69T CNC Modder
    6 Jun 2004
    Thanks guys! ;)
    What's a VMC?
    Yes, the tool moves with 2 interpolated axis on the profile (X and Z-axis) , this one is repeated with multiple Y-axes steps (sorry for my english :wallbash: ).
    Bye bye :thumb:
  7. JavaDog
    JavaDog New Member
    13 Mar 2004
    Vertical Milling Machine. :D
    EDIT: Ha, in my haste I screwed it up - VMC = Vertical Machining Center.
  8. DR_D
    DR_D New Member
    8 Nov 2005
    VMC = Vertical Milling Machine???? That doesn't match the acryonim!
  9. G69T
    G69T CNC Modder
    6 Jun 2004
    :wallbash: thanks ;)
  10. G69T
    G69T CNC Modder
    6 Jun 2004
    @ praetor coda
    Looks these images of the simulation working phases. ;)
    Z O O M !
    Bye bye ;)
  11. G69T
    G69T CNC Modder
    6 Jun 2004
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    You'll sleeve those cables, won't you?
    Except that (of course temporary) 'awesome as usual'. :)
  13. G69T
    G69T CNC Modder
    6 Jun 2004
    It's only an assembling test ;)
  14. JavaDog
    JavaDog New Member
    13 Mar 2004
    Er, Vertical Machining Center... :duh:
  15. dom_
    dom_ --->
    4 Jan 2004
    Excellent work. Cant wait for the finished pc.
  16. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    :D I cant stop grinning while seeing the new pics. Keep it up!
  17. Deathrow
    Deathrow Member
    30 Jul 2005
    Amazing work G69. I really envy your CNC skills and only wish I had some equipment like that at my disposal it must be alot of fun to play with.
    I hope the remainder of the top half can live up to my expectations after the water station put the bar so high.
  18. nyzrox
    nyzrox New Member
    27 Nov 2005
    is tht a seasonic i see *** i love mine
  19. Klekkus
    Klekkus New Member
    5 Nov 2005
    Great work on that back plate, how much remaning of the case?
    I also got some part made on a CNC for my case, here are a link. I treaded it for a lexan plate on 1x400x250mm :D
    The guy who made it used two hours on it, and he works with the CNC every day. So what do you think about jis work then?
  20. vash
    vash New Member
    3 Feb 2006
    Hi CNC-man , Your work it's beatiful and i think U're a little bit crazy to concept this fantastic work!!
    But I've a terrible question....hehehe
    What kind of soft do you use to create the cad-design and interface with CNC?
    CATIA?solidworks??
    ;M)
