Scratch Build – In Progress Dark Blade by G69T
Discussion in 'Project Logs' started by G69T, 30 Nov 2004.
  1. praetor coda
    praetor coda What's a Dremel?
    6 Aug 2005
    I know how you did it..., I was asking about the cutting bit. I just assumed, from the angle of the picture, that you were using a standard flat ended bit utilizing some improvised technical know-how
  2. Liquid
    Liquid What's a Dremel?
    20 Jul 2005
    impressive staff...
    what´s the name of that software you have... drawing stuffs for your projects... beautifull :rock: :rock:
    :thumb:
    ps: have some question for you :D
  3. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Good lord! it's very pretty.
    One Q for you, and a real pet peave of mine w\ a LOT of mods (including my own...) You do all this lovely work on a chassis or creating one from scratch and you're still stuck with this butt-ugly ATX IO shield. My next creation won't have this darn thing, the board will sit inside the case and I'll do breakout cables. I just can't stand looking at the plain old shiny ATX IO shield... ick. Or the standard ATX IO layout, for those who have taken the time :)clap:) to create their own IO cutouts!
  4. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    It's because every mobo is unique (pretty much) in it's layout. By leaving that space blank you allow for future upgradablillity. I'm pretty G69T will be remanufacturing that plate out of alluminium to replace the crappy tinplate one.
  5. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I only found this thread today, there should be a permanent link on the main page of the modding section. The attention to detail of this case is utterly flawless, mayb not completely my taste, but i can't help but be amazed with everything you have done.
    Well that's a whole morning of work wasted reading through this thread, think i managed to get about 5 min of designing done (architecture) boss will be happy!!
    Can't wait for next update, bring it on...............
  6. ToastSAVY
    ToastSAVY What's a Dremel?
    3 Feb 2006
    Fantastic work CNC GOD!!!! I've joined the forum having followed a link to the thread and spent the day reading the whole thing. :baby: :thumb: :clap:
    It's been a long while since I was in the modding mood having grown bored of the stock window cutting, light fixing, cable tidying... jobs that form the majority of modding, but your project has really given me inspiration. Keep up the goodness!!!
    One question... with so many bit of metal screwed together is there any likelihood of vibration noise? Are you employing rubber gromits to keep vibration to a minimum or perhaps precision milling / tooling minimises vibration anyway?
    :thumb: :thumb:
    Toasty
  7. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    I agree with Starbuck3733T and Constructacon; to me the ATX IO shield breaks the style of the case.
  8. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    yeah you should make a cover for that part of the case.....
  9. hobogoblin
    hobogoblin What's a Dremel?
    6 Feb 2006
    Unblievable craftsmenship,Seariously amazing man.
  10. G69T
    G69T CNC Modder
    6 Jun 2004
    Thanks to all! ;)
    Nice CNC work. ;)
    I use a specific Italian cad-cam software for my cnc milling machine. I sent you an private message about their name. ;)
    I have used a standard flat ended bit for the columns working. ;)
    Z O O M !
  11. G69T
    G69T CNC Modder
    6 Jun 2004
    At the moment, I have not definite the hardware options for my Dark Blade mod, I have chosen a standard solution for this detail.....but all pieces are modifiable. ;)
  12. G69T
    G69T CNC Modder
    6 Jun 2004
    Thank you Toasty for your bit-tech forum signed and your comment! ;)
    When the cnc milling machine is working, the aluminium vibration noise is low (and absent when I work the big raw material pieces) and the tools noise is absent.
    Bye bye :thumb:
  13. leviathan18
    17 Mar 2005
    you can make a little acrilyc plate like you did in the waterstation.. just to cover the whole part...
  14. Starbuck3733T
    16 Sep 2002
    Nobody says you have to make a plate - I'm advocating the use of a breakout area, or multi-cable conductor to external breakout pigtails.
    G69T: I'm not downing your work by any sense of the imagination - just starting some discussion :)
  15. praetor coda
    6 Aug 2005
    thanks G69T, thank you for sharing your build with the rest of us.
  16. Static Lullaby
    Static Lullaby What's a Dremel?
    1 Feb 2006
    I think he was asking if the case will deal with any vibration noise once it is put together? If you are utilizing anything specific in between the joints? (Grommets etc)
  17. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    If the case weight estimate is correct at 40-50KG then its going to take a lot to make this case vibrate.
  18. niktard
    niktard What's a Dremel?
    21 May 2004
    just amazing !
  19. thriteenthmonkey
    thriteenthmonkey What's a Dremel?
    19 Jan 2006
    I thought it was 20 kg so far
    either way it's really heavy
  20. adnan
    adnan What's a Dremel?
    9 Feb 2006
    Amazing.
    Deam dude, this is just AMAZING, when i look at your work it makes me take a nother education.... :p keep the good work coming.
